DIY: PAC Steering Wheel Controls (W/ Pics)
Old Apr 15, 2009 | 02:57 AM
jin22gt's Avatar
Peter: Do you know if the pwr button can be used with the pac swi-ps?
Old Apr 15, 2009 | 08:01 AM
Vrod-Mike's Avatar
You shouod be able to program any of the radio buttons to do any function you want. For example I programmed my pwr button to mute the radio.
Old Apr 15, 2009 | 04:21 PM
PeterUbers's Avatar
Pwr button, yes, but you cannot use the "Phone" button -- has a picture of a telephone on it. Nor can you use any of the cruise control buttons (obviously, but had to state this fact)
Old Apr 17, 2009 | 02:01 AM
jin22gt's Avatar
quick question:
Can I criss-cross the end of the resistors(150ohm and 47ohm) together and solder the white wire on to it?
Old Apr 17, 2009 | 12:14 PM
PeterUbers's Avatar
yes
but make sure you reinforce the whole thing with something solid .. like a piece of plastic as the resistors are very weak (the metal tongs) and they can break over time..
Old Apr 17, 2009 | 12:31 PM
Mike_Deezy's Avatar
Nice write up. I need install a DD in my car soon.
Old Apr 17, 2009 | 07:12 PM
jin22gt's Avatar
I can't put two commands onto one button? ie. I want to use the mode button to change sources and pick up the phone. Is this possible? Thanks
Old Apr 17, 2009 | 07:21 PM
Vrod-Mike's Avatar
No you can only have one command for each button.
Old Apr 18, 2009 | 04:31 PM
jin22gt's Avatar
Thanks for the help guys!!!
I got the pac-swi-ps to work! The problem was that the resistor was broken and that caused the problem!
It was fairly easy to program. The hardest part was taking the entire dash apart.!
Good job on the write up! This will come in handy for alot of people!
Old May 24, 2009 | 04:46 PM
loki05's Avatar
damn! i should of just soldered the wires together to begin with, it was so easy doing it that way..
connecting to the pins or tapping wires didnt work at all for me!
but the diagram is dead on.
Old May 24, 2009 | 08:36 PM
jin22gt's Avatar
Im having problems with only the next track button. It seems to only work sometimes. What could the problem be?
Old May 24, 2009 | 08:42 PM
DrTomSlick's Avatar
I'm having probs with my PAC SWI. When I first installed the unit, it was working perfectly for about a couple of weeks. Then all of a sudden it would quit working after driving for more than 20 mins. The next morning everything worked fine but again it stopped working after 20 mins of operation. Does anyone else have this problem?
Old May 24, 2009 | 08:43 PM
jin22gt's Avatar
what HU do you have?
Old May 24, 2009 | 09:00 PM
DrTomSlick's Avatar
I'm pretty sure it's a Pioneer AVH-P4000DVD Double DIN Non-Navigation.
Old Sep 27, 2009 | 09:27 PM
  #30
tyeayo's Avatar
AWSOME RIGHT UP!!!! Just got done doing this and it took me all of 20 minutes (Already had my aftermarket head unit in, just not "secured") Major props to the original poster!! Great write up with good pics and clear and concise instructions
