AMP Question
Old Nov 18, 2008 | 06:31 PM
Nyteowl's Avatar
AMP Question
I did some research and could not find the answer or maybe I didn't know what I was looking for.
anyways, I bought a head unit that only supports 4 x 60 Watt Max High Power Output. Right now, it sounds like crap
My question is, is there a way of using the amp? A guy told me I have to buy an equalizer to get more out, do I need to do this or is there another option.
thanks in advance
Old Nov 20, 2008 | 01:04 PM
digitalhifinet's Avatar
Whomever you spoke to supplied you with erroneous information. If you already have an aftermarket HU installed you don't need an EQ. The first thing I would check is to make sure you have bypassed the BOSE factory amp, because will make your setup sound like a whistle tip muffler no matter what you do. There should be numerous threads on here to explain how to do this. If you've already done that and upgraded your speakers, then I would consider an amp if you still aren't getting the volume out. But simply bypassing the BOSE amp and running HU power should give a vast improvement over the stock sound.
Good luck!
Old Nov 20, 2008 | 02:51 PM
blazeplacid's Avatar
thanks in advance
first off what kind of radio is it ? model number?
are you using the ipod/cd/tape??
If the signal is bad to begin with then your output wont be any better.
I would add an amp to ANY aftermarket or factory radio. Get A decent name brand amp and you will be golden.
Whats your budget on an amp?
hdmark
Apr 29, 2019 04:31 PM
broke_as_ajoke
Nov 6, 2015 11:49 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Thunderaan
Jul 22, 2015 07:40 PM
