How do I make my aftermarket HU louder?
Old Nov 26, 2008 | 08:00 AM
luckiedave's Avatar
Hi i just installed a Kenwood DDX512 into my 04 G35 coupe. I got the double din combo kit off ebay which had everything with it, and it definitely looks great. My only problem is that the only way to make it loud is if i turn it up all the way, and max out the volume. i have the stock bose system, and with the original HU it would get pretty loud. Is there any way to fix this? Thanks.
Old Nov 26, 2008 | 10:04 AM
TroysG's Avatar
what harness did you buy? one with RCAs going into the speakers or straight wires where you had to wire the + and -?
the RCAs will be quieter because there's a lower signal going into the amp.
the straight wires will give you a louder sound but there's a higher chance on distortion.
Old Nov 26, 2008 | 10:25 AM
blazeplacid's Avatar
this is why I didnt get the Bose set up
ive heard people having this problem
Id get an amp and run your speakers that way
I dont know if there is a way to "turn up" the gains on the bose amp.
Old Nov 26, 2008 | 02:45 PM
TroysG's Avatar
honestly. the bose system in the G really isn't a true bose system at all. the headunit is clarion. so you can swap out the deck easily. it just comes down to the wiring harness you use.
Old Nov 26, 2008 | 04:57 PM
luckiedave's Avatar
Hey thanks for the responses. So I do have the RCA jacks hooked to the headunit, so like you said it's probly why it's lower. Now I didread about a type of 2 line converter... Anyone know anything about that?
Old Nov 26, 2008 | 07:29 PM
TroysG's Avatar
you don't need that for just installing a deck. if you swap your harness to the 7550 version it will be louder but as I previously stated. higher chance of distortion
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
Frostbite91
Aug 12, 2015 05:16 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
