RCA to Dock cable
Old Dec 29, 2008 | 03:13 AM
rob40wilson03's Avatar
RCA to Dock cable
i just ordered a PAC AAI-NIS2 to hook up my iphone 3g but I want to charge it also and I've seen it posted that the PAC RCA to Dock cable can be bought for around $20 but I need to know where.... i can only find the thing on just a very few places online and it's pretty expensive there
here's what i need:
http://www.pac-audio.com/products/pr...egration#ic-AV
pretty sure i need the ic-av2 since i have the iphone 3g
Old Dec 29, 2008 | 05:25 PM
fishhouse's Avatar
^ you have several options. namely, do you want powered or non-powered and do you want one for only iPods or for iPods/iPhones.
if you just want a powered iPod one it'll look like this. a non-powered version looks the same less the small red live wire and black ground wire.
if you need one to work for a iPod and iPhone, it'll look like this. note the yellow video wire - you need this cable for the iPhone even if you do NOT plan to connect the video wire...just tape off the yellow RCA wire and leave it unplugged. again, a non-powered version will look the same less the small red and black wire.
i've purchased one from both of these ebay vendors for $10-$20 plus shipping and would recommend either - they both sell the cables mentioned above:
Exclusive Parts HK
12 Volt Parts
i'm almost 100% sure that to get the 3G to charge you'll need an adapter like this.
Old Dec 29, 2008 | 09:18 PM
fishhouse... the link i included earlier says (about the ic-av2) that it works for all ipods and iphones... i assume that means that it will successfully charge the iphone 3G also..... or am i wrong to assume that?
Old Dec 29, 2008 | 09:55 PM
fishhouse's Avatar
yea from what i can tell the ic-av2 will work with everything (sorry thought you were talking about the older ic-av) cable.
how much are those ic-av2 cables btw?
Old Dec 29, 2008 | 10:46 PM
they are $35 at this site....
http://www.jazzyengineering.com/prod...products_id=51
and that is almost the only place i can find it
i guess i'll just buy it since i got the PAC unit for only $70 shipped on ebay when it's normally $99
is hooking up the power wires simple to do while following the various guides for installing the PAC?
Old Dec 30, 2008 | 09:37 AM
fishhouse's Avatar
nice - yea i picked mine up on ebay for the same...we might of got it from the same seller.
my how-to at my site www.myG35mods.com walks you through everything - all and all it's very easy.
as far as the power wire specifically, i used a small wire tap and spliced into the live cigarette lighter wire (it was green i believe) and the used one of the metal screws holding in the headunit for the ground.
Old Dec 31, 2008 | 12:54 AM
yeah i've seen your guide for the installation... well done!
do you have any idea if those "hollow spaces" are present in the 6MTs?
Old Dec 31, 2008 | 01:51 AM
fishhouse's Avatar
hmm good question. not sure but i don't think you'll have a problem finding somewhere to store it regardless. good luck!
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
JustinMKN1
Sep 18, 2015 03:40 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
