USA Spec Vs. Perpherial Elect. PXAMG-A
#46
Oh, you have to have admin rights on the computer to install the driver. Maybe the shop guys don't have that? But you'd think a computer store would know that. Maybe they need to call the Geek Squad!
#47
so wait, i need to actually switch some switches on the actual box??.THe guy(s) at best buy told me they went to the site and downloaded the firmware, but for some reason their vista wouldnt recognize the driver or something...it wouldn't install....it was a weak excuse....i cant go back until this weekend, cause i live in an hour from the closest best buy...
#48
they did call the geek squad....and apparently they couldn't fix it...it seems like bullsh-t to me..personally...I am annoyed...it was pretty muchh the only other thing i was looking forward to this weekend (apart from installing my ztube and my mudguards [rear])
#49
#50
Hi guys!
I bought the Perpherial PXAMG unit with the PGHNI1 harness for my 04 coupe but when I connect it I doesn't have sound on right side speaker?????I update the firmware and it said ''Succesful''.I does everything like they said dipswitch 2 ''on'' plug the harness of the ipod in the port on the left (furthest away from the dipswitches) so what wrong??? My radio is working great ,I put balance right or left all speakers are good.If I let the balance full right and plug the Ipod I can listen some music but at Max volume only.
My Ipod is upgrade to the latest version to.
So if you have any Idea let me know!!
thanks
thanks
#51
#52
on ipod or aux2 its the same no sound on the right......I would like to return it but i bought it used on ebay.
#54
yes I got the pxamg and my version is PXxxxxx.36 so I upgrade the firmware for the .36a but I doesn't have sound on the right...so I just write to them and im waiting for their respond.
#55
Elmecano, you can call costumer service at Ph. 800-477-2267 ext. 230 and talk to them directly. They were pretty good when I was installing my unit and solved one problem on the spot (I had no sound b/c the unit was not on ipod mode when I first connected my ipod). I would check all cables connections to make sure there are no bent pins in the plugs going into the PXAMG unit or loose connections going to the HU. After that I would imagine you could have a defective unit. Good luck.
#58
The 3.5mm (or RCA jacks) are used in "aux2" mode if attached. Then everything is controled from the ipod (but can't from HU). The steering wheel controls won't do anything either. But you can connect non-ipods this way.
#59
Wompen and Katacoo,
Do any of you have 3.0 installed on your iPhone/Touch(s)?? The sites say that the PXAMG is not compatible with 3.0 but it doesn't specify what exactly isn't compatible or not working...
Can you guys please explain? That's the only thing holding me back from buying this adapter at the moment...
(BTW, I have an iPhone 3Gs (32GB) and 05 G35 Sedan w/ Bose)
#60
