Battery dead after DD install
Did i do anything wrong with my DD install, since my battery has been flat 2 times in one week? still havent driven my car yet tho, just played around with the player for max 10-15 minutes.
My DD is wired up with the 7550 to the original 225w Bose amp.
When i installed the DD i did not get any sound from the Bose amp, but found out that i had to go in the menu and set up the player to give power to the amp, but i wonder if this gives power constantly to the amp, even when the player is off.
do you have a digital multimeter?
is the deck still on when you turn the car off?
also did you hang out in the car when the car was not started?
battery could have just been drained from hanging out in the car and playing with the deck if the car wasn't started
Yes i do have a digital multimeter, but i have to disconnect everything to do it.
the deck is turning off 5 seconds after i take out the key from the inition.
I did hang out in the car for about 10-15 minutes, with the doors open, and the roof lights on, and i did not start the car.
If the battery is dead, and i have to replace it, how many amperes is the stock battery?, the one thats in my car doesent look original, and could be a smaller amp
ok boost the battery so that you can start the car. let it run for about 15-20 minutes
turn the car off and put your meter on voltage, go to the battery and see if it drops significantly
after about 15-20 mins of run time you should have a reading of 12.6 or so.
Bought new battery two weeks ago, it was then fully charged, the car have not been used since then, today i went out in the garage, and the battery is flat.
Something must be wrong after the DD install, but what?
try redoing the ground on the back of the deck. - disconnect it from the existing ground in the harness and extend it to a piece of metal attached to the chassis. Use your multimeter to check for the area of least resistance. You'll need a self tapping screw.
Aha, when i think back, the deck did not work before i put in the antennacable, so that could be the answer to my problem, ill make a solid ground tomorrow when my battery is fully charged
Try this. Take an amp reading on the negative side on the battery after you ran it, shut th key off and let it sit for about 10-20 minutes. I don't know how many amps your meter can do so it may blow the fuse. There shouldn't be much at all if normal, an amp maybe 2 I think for these cars. if it's more that means something is on that shouldn't be. Leave it connected and start unplugging fuses one at a time. If the amps don't drop that circuit is fine, put the fuse back in. If you think the radio is the issue, start there.
Hope this helps.
Hope this helps.
With the multimeter he should check for ANY voltage on all the wires he connected. see if there's some voltage hopping going on. It's rare but I've seen it on a couple decks - obviously it was a problem from the manufacturer
What about the amplifier turn on lead? could it be that the amp is constantly constantly getting juice on accident?
