problems with 03 clock
Old Jan 31, 2009 | 02:53 PM
liG35c's Avatar
I have a 03 coupe. When I bought it both lights were out in the clock. Keeps time fine though.
A friend of mine works at a dealership and got me the OEM bulbs cheap.
I put them in and it worked fine for 5 days or so (although dimmer then I thought it would be) and now pitch black again.
Is this common?
Old Jan 31, 2009 | 04:57 PM
xXHotelCrazyXx's Avatar
Is this common?
Check your fuses...
Old Feb 1, 2009 | 08:11 PM
chrischil's Avatar
wait...so the clock is SUPPOSED to light up!?!??!?!
Old Feb 1, 2009 | 08:20 PM
Rodrigo's Avatar
yes the clock lights up, if you installed new bulbs you should also install a new fuse just to be safe.
Old Feb 1, 2009 | 08:23 PM
Hi-TechG35's Avatar
Check the fuses as mentioned and yes the clock lights up!
Old Feb 1, 2009 | 09:02 PM
liG35c's Avatar
can anyone tell me a # spot for the fuse? My car didnt come with a manual
Old Feb 1, 2009 | 11:53 PM
johnparkyourcar's Avatar
can it be a fuse even though everything else works except the clock lights? I replaced my bulbs and less than a month later both stopped working... im too cheap to keep replacing it so at night i can't see what time it is.
Old Feb 2, 2009 | 08:52 AM
chrischil's Avatar
I just bought my car from Carmax 2 weeks ago..an 03' coupe...i just thought the clock didnt light up...you're tellin me it's a fuse problem, when everything else works just fine??
Old Feb 2, 2009 | 09:11 AM
RBull's Avatar
Rated M
The lights are always dimmer than the dash lights however I'm not aware of a common problem with them going out.
I doubt the clock light has a separate fuse. Is it possible to trace the wire back to the fuse panel/harness to make sure it is good?
Old Feb 2, 2009 | 09:36 AM
waijai's Avatar
i.love.gold
Bulbs most likely went out again.
Old Feb 2, 2009 | 09:47 AM
Mitsuko's Avatar
the bulbs suck, they always go out easily. your lucky you're friend got em for you for cheap, cause they tried to charge me $20 for each, and I needed 2. So $40 for my clock to light up for a few months and blow again? I said f-that and retrofitted some LED's. Easy if you know basic wiring.
Old Feb 2, 2009 | 09:59 AM
EL-EE-ES's Avatar
you can get leds the replace the oem bulb...someone posted a site that has them a few months ago, you should be able to search here to find it
Old Feb 2, 2009 | 02:45 PM
liG35c's Avatar
ok thanks guys
Old Feb 3, 2009 | 08:57 AM
chrischil's Avatar
grrr...i dont wanna take apart my dash to replace lightsd in my clock...
Old Feb 3, 2009 | 09:45 AM
waijai's Avatar
i.love.gold
crybaby?
