Stock stereo back in - NO POWER
Old Feb 1, 2009 | 08:20 PM
phatbuddha's Avatar
I just pulled my stereo and put the stock stereo and AC control back in. Now I don't get any power to the stereo or AC, just a single loud beep and then that's it. Nothing lights up...nada. However, it does sound like the CD motor is trying to do something.
I didn't cut into the harness at all, but used a wiring adapter. The stock amp and NAV brain have all been put back in.
The only thing is that I have 4 ohm speakers in the back that I don't even want to try and remove, so I have a 2 ohm signal running into 4 ohm speakers in the back, but I can't imagine that would keep the stereo from even firing up.
Any thoughts guys? Your feedback would be GREATLY appreciated.
Thanks
Old Feb 1, 2009 | 08:29 PM
Hi-TechG35's Avatar
Theres a little hidden wire that runs from the circuit board to the radio. Is that in?
Old Feb 1, 2009 | 09:16 PM
phatbuddha's Avatar
What hidden wire?
Old Feb 2, 2009 | 11:40 AM
TroysG's Avatar
check fuses, make sure everything is plugged in
Old Apr 23, 2009 | 12:20 AM
dmsteele92831's Avatar
I just had this problem happen and searched on here for the solution but couldn't find one!! What it was is that there is a small green film insert plug that connects to the back of the faceplate at the bottom right hand side. Somehow that came out when I pulled the head unit and and I started checking everything and that was the problem. So I put it back in its slot and that fixed it!
Old Apr 25, 2009 | 02:08 PM
PeterUbers's Avatar
Yah... that's the ribbon cable that connects the CD changer and pre-amp to the control board!!!
Look for this at the base of the unit
EnCr1pt3d
Jul 8, 2019 02:48 PM
hdmark
Apr 29, 2019 04:31 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
apintojr
Jul 23, 2015 10:52 AM
