Can I install a power inverter...
Old Feb 13, 2009 | 10:29 PM
Trasher's Avatar
under the center console near the rear section? I run my computer all day long and have a power inverter running out of my center console and to the RR floor, just laying there. Kinda tacky... I want to stuff one under the console with only the plug exposed so I can plug into it. Is there room under there for one?
Old Feb 14, 2009 | 11:36 AM
Dan in St Louis's Avatar
They come in all different sizes, check out a variety on amazon.com.
Old Feb 14, 2009 | 01:22 PM
Trasher's Avatar
The one I have is only 4x4x2. Is it pretty open under there or is it a tight fit?
Old Feb 19, 2009 | 08:42 AM
GrocryGettr's Avatar
I wouldn't put it under the console. An inverter needs to stay cool and there's no airflow under the console. I would suggest a lighter adapter for your laptop as that's what I use and have never had any problems.
Old Feb 19, 2009 | 08:52 AM
Deezflip's Avatar
+1 on a car adapter, you should be able to find one that has the right voltage and amps for the your laptop.
Your regular home adapter for your laptop is already converting AC to DC. Basically, the car is dishing out DC already. If your getting a power inverter, it's doing to much converting from DC to AC then back to DC again.
Old Feb 26, 2009 | 11:31 PM
Trasher's Avatar
Good idea. I'll check into it tonight. I have had so many computer issues lately that I have 2 computers with me all the time ( ones the company unit and the other one is my own). The bad thing is that they are different models which would mean I would have to get two chargers
Old Feb 27, 2009 | 09:47 AM
Not necessarily. I have a Gateway laptop and Fujitsu Tablet PC that I sometimes carry together. I went to Walmart and bought a universal charger and it comes with different plug-ins for all types of computers. Works great for me.
Old Feb 27, 2009 | 11:42 AM
racefan318's Avatar
once you figure out what chargers you will use, you can add add'l cig lighter outlets and keep them plugged in and out of the way...
Old Feb 27, 2009 | 03:48 PM
ttrank's Avatar
Grocery getter
Just make sure it has enough air to keep cool.
Old Feb 27, 2009 | 03:55 PM
TroysG's Avatar
what I'd suggest is if you want to hide it. put it under the seat or whereever you had it. get a small extension cord, dremel a hole to fit it in your centre console, put your extension cord end in there, fasten it, and now you only have your plug in the centre console, for your laptop, microwave, george foreman whatever floats your boat
Old Feb 27, 2009 | 03:57 PM
Texasscout's Avatar
Where ever you put it, it MUST have ventilation. Those things get hot!
willdogs
Dec 8, 2015 11:32 AM
Danielek
Aug 11, 2015 09:33 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
