DD finisher. HELP!!
Old Feb 21, 2009 | 02:25 AM
gizmo134's Avatar
DD finisher. HELP!!
so im working on putting a DD in my car, and i found that the DD is too big to let the navi controls fit. what do i do???!!
Old Feb 21, 2009 | 09:52 AM
TroysG's Avatar
what DD are you using? and the heater controls just screw into the finisher
Old Feb 21, 2009 | 12:41 PM
gizmo134's Avatar
i got the JDM one through Infiniti. the HVAC is fine, its just the navi controls. my stock finisher is a little shorter, and the navi plate screwed onto the back. the new finisher has like a top edge, and is too tall. if theres not one that fits, my option looks like breaking out the dremel
Old Feb 21, 2009 | 12:49 PM
naughty240's Avatar
Maybe you have the non navi one?
Old Feb 21, 2009 | 12:53 PM
gizmo134's Avatar
is there a navi version?
Old Feb 21, 2009 | 12:54 PM
Gone-G's Avatar
/\ +1
Old Feb 21, 2009 | 12:59 PM
TroysG's Avatar
strange... maybe you didn't screw the navi into the right spot, or you screwed the bracket into the wrong spot. I know sometimes there's 2 holes one to hold the bracket into spot and one to screw into - if that's the case shift it up a bit. I know my Navi is tight now. sometimes I have to give it a lil pull to bring it up... but if it's that it's too tight there's a could screws you have to loosen up. I can't remember which ones off the top of my head. Sorry
Old Feb 21, 2009 | 01:40 PM
gizmo134's Avatar
the navi wount fit to the holes on the finisher. when you line the holes on the 2 finishers up, the DD one is about 1/4 of an inch taller than the stock. the screws are then 1/4 of an inch too high, and if you screw the navi controller to the console frame and try to put the DD on, theres that overlap.
Old Feb 23, 2009 | 06:21 PM
gizmo134's Avatar
aright so i called Infiniti, they said that theres only one and that theyve never had an issue with it. idk whats wrong with it, but for whatever reason its too long. guess im just gonna try to fix it, any ideas?
portgirl
Cars for Sale CDN
May 12, 2013 01:54 PM
snotf
Archived Sales
Dec 4, 2008 11:32 PM
f50bodykit
Jul 12, 2006 09:34 PM
