Install this week where to route power wire
Old Mar 2, 2009 | 12:03 AM
gwilli3272's Avatar
Okay I am starting my install this week. I would rather not drill a hole through the fire wall. Is there a spot in the fire wall that I can run the wire through that already exists? If so where is it? I have seen the write up for adding an after market sub and amp, but it does not say what year the car is. Mine is an 05, and I do not know if the spot to run the power wire through the fire wall is in the same spot on all.
Old Mar 2, 2009 | 01:45 AM
Shakuya88's Avatar
If it was me, I'd just search for a grommet that isn't full of wires already. My guess would be MAYBE get it through the grommet of the main harness depending on AWG of wire. I'm doing mine soon so I'll be paying attention to this thread for the right answer.
Old Mar 2, 2009 | 02:26 AM
G35 Mass's Avatar
There should be a grommet right behind the battery. Make a new hole, run your wire through, and seal it up with silicone.
Old Mar 2, 2009 | 03:12 AM
gwilli3272's Avatar
Well that was easy. So it is in the battery compartment. That I will be able to find easy. Thanks.
Old Mar 2, 2009 | 08:23 AM
blazeplacid's Avatar
you will have to cut the rubber to make any wire fit
I have two runs of 4 ga running though and still have room
For added safety and to be sure no water comes though, you can "seal" it with silicone
Old Mar 6, 2009 | 02:25 AM
MotoCARR's Avatar
G35 Sedan
Follow my sticky at the top of the forum
Old Mar 7, 2009 | 10:04 PM
gwilli3272's Avatar
Well this is a pain in the a$$. I have been at it since 11am and I am not done yet. Speaker wire ran to all doors, power wire ran for amps, speaker wire ran to the trunk (except for passenger rear). Getting the molex out of the drivers front was easy, but putting that bastard back in, jesus freaking christ; it only took about 2 hrs, that SOB did not want to go back in. Passenger front was not near as bad as the drivers, rear doors were much easier though. The Bose stereo is out, sad to say the F90BT is not in as of yet. Hoping tomorrow I can get this done. I am taking my time to get done in good working order. I bought 70ft of speaker wire though, 12 gauge. Should be enough for all 4 doors and a sub. Pick up the box on tuesday.
EnCr1pt3d
Jul 8, 2019 02:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
