OEM Navigation wiring problems
Old Mar 11, 2009 | 06:38 AM
xbird's Avatar
actually, i don't plan on running a DVD player...
i really just want to use the OEM monitor to use the reverse camera.......
i think i have made some progress today, the camera does turn on... BUT... really hard to tell, coz i am not sending any signal into the video input....
how do i check if i am hooking the wires correctly? which wires should i connect to send the video signals in?? let's say if i hook up a home DVD unit, then connect the RGB wires to it, would it work??
which wires do i need to connect? i can see i need to connect the RGB, the ground, and the pink for synch signal?? what is a synch signal??
thanks
Old Mar 11, 2009 | 07:39 AM
TroysG's Avatar
Wish I could help man but chances are with that you will have to do some guessing.
put fuses on the wires just in case.
EnCr1pt3d
Jul 8, 2019 02:48 PM
Frostbite91
Aug 12, 2015 05:16 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
stay_tuned
Jul 21, 2015 07:09 PM
