Hardwiring a USB port
Old Mar 12, 2009 | 05:34 PM
cheno848's Avatar
I want to add a usb port into my 04 G so that I can use an ipod dock in addition to my AAI NIS2 aux in.
Here is what I am thinking. Cut up a female usb connector that I have so I can get the wires. Then I need to wire the positive to a 5V source behind the dash and ground the negative. Are there any 5V sources I could use or should I just use a resistor and tap a 12V source like the radio? Would I run into any problems doing this?
Here is the usb pinout
http://pinouts.ru/Slots/USB_pinout.shtml
Old Mar 12, 2009 | 06:12 PM
TwilightG35Guy's Avatar
way more work than needed..... check this out
http://cgi.ebay.com/USA-Spec-PA11-NIS-Nissan-Infiniti-IPod-Adapter-FREE-S-H_W0QQitemZ120322544455QQihZ002QQcategoryZ58350QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
it has rca inputs as well...
it took me maybe an hour to install
Old Mar 12, 2009 | 06:16 PM
cheno848's Avatar
I thought about doing that but I got my aai nis2 for 40 bucks on ebay. Thats why I need a charging method. I already have the usb parts so I may just need a resistor so my total cost would be like $45 if this works.
Old Mar 12, 2009 | 06:27 PM
well if you are going that way with it i"m lost... i just spent the extra 100
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
1Typhoon
Sep 25, 2015 08:45 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
Cacoepy
Aug 3, 2015 01:09 PM
beevanhuynh
Jul 14, 2015 09:06 AM
