Need help? Trunk WIRES question
it looks like the bose input harness is completely cut off. That would be the blue harness. If you look in the 'add a sub' sticky you will find which wires do what. Then you can connect them to a new amp and plug back into the factory output wires. That's a really crappy thing to do to a new owner. I spliced into my harness just so that someday i wouldn't screw another owner over (rather keep it till it dies though)
The two that are closest together are the two for the bose amp. The other one thats closer to the back of the trunk is for the bluetooth handsfree unit. To add an amp you can follow the sticky guide that everyone else was talking about, but if you want fade control for front and rear, or want to do your fronts on the front fade and maybe your sub on the rear fade it doesnt tell you which wires.
For front speakers, the input wires are...
Front right + Orange/blue
Front right - White/blue
Front left + White
Front left - Orange
These are the wires from the headunit, if you want to tap in to the speaker wires, its different. Off the top of my head i only know that the Green and Red stripe silver wires are for front left, i would have to look at the rest, let me know if you need them. It wont matter if youre using your own speaker wires though.
Front left + White
Front left - Orange
FS[Texas]: KSport Air Suspension G35/350Z/M35
privatecorye
Steering & Suspension
05-31-2016 01:56 AM
