Features
Old Jun 28, 2004 | 09:31 PM
KPierson's Avatar
Re: Features
If you hold the 'unlock' button down on the remote the windows lower. I really cool feature until find out you have to use the key in the door to get them back up......
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Jun 28, 2004 | 09:48 PM
GoSooners's Avatar
Re: Features
I don't know if you tried it yet but if you put the pedal to the floor, you'll hear such sweet sounds...it's an orgasmic experience.
Black on Black 5AT Coupe, Navi
Falken Koblenz 19x8.5 F 19x9.5 R
Falken FK-451 245/35 F 285/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
Old Jun 29, 2004 | 12:59 PM
nate1749's Avatar
Re: Features
I love the small things that I'm sure you've already noticed, such as the vents and how the entire steering wheel console moves. I also found another card holder above the passenger's vanity mirror. Putting your key in the door and turning it will roll them down, turn the other way and it will roll them up. In order to get your windows to roll up through the key fob, you can buy a device made by another forum member. There are many threads on this, and one VERY long one, and he has a web site where you can purchase it ($50).
You can pull the lever behind the passenger seat for it to move forward and I'm sure you've found the emergency kit in the rear armrest, which has some interesting stuff in it (maxi pad/gauze pad).
You've got homelink, so you can program your garage/gates, but there is also a DIY on programming the buttons to do other functions, such as pulling up long menus on the navigation system.
You can also change cds with the steering wheel by holding down the track up/down position. Also, when ejecting a cd you don't have to select the cd # if the one you want ejected is the one that you're currently on. If you play with the stereo audio button you will find an SCV option, which will automatically increases/decreases volume depending on your speed.
If you don't know about VDC, read your manual & the thread below. In my opinion, this is one of the most important/neatest feature your car has, which surprisingly a lot of people didn't know anything about when purchasing.
https://g35driver.com/forums/showfla...view=&sb=&vc=1
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
stratous01
Oct 7, 2015 10:19 AM
1Typhoon
Sep 25, 2015 08:45 PM
wayneside
SouthEast
Sep 23, 2015 06:38 AM
