New G35 Driver, Audio Noobie, DD+Amp+SUB Questions
Old Mar 18, 2009 | 02:03 PM
willcho415's Avatar
Hi guys, i just got my g35 on sunday and im proud
I actually wanted to put in a double din dvd deck into the car and i have the PIONEER AVH-PH4000DVD.
I also have a Bazooka ELA 300.1 AMP (200x1 @ 4ohm & 300x1 @2ohm)
and i also have POLK GNX10 Sub (175w continuous, 400w peak, 4ohm impedance)
Now here are my questions:
1) Is my amp and sub and dvd deck setup okay to use or will i come up with an electrical problem?
2) I am still not sure which gauge amp kit i need (as i searched google and came up with nothing -.-)
3) I bought the METRA 99-7604 dash kit for the G. Do I have to cut the middle to make it a double din?
4) I basically need the attena adapter, NNo3B wiring harness, amp kit, and a tug switch (for dvd play while driving) to run everything right? or am i missing something?
Old Mar 18, 2009 | 02:22 PM
TroysG's Avatar
you can use an 8gauge wiring kit, you need antenna adapter, and the 7550 wiring harness. you don't need the NN03B harness. you're amp/deck will work together
Old Mar 18, 2009 | 03:11 PM
willcho415's Avatar
i dont know where i can buy the metra 7550 harness locally lol but would the nn03b still work?
Old Mar 18, 2009 | 03:16 PM
TroysG's Avatar
7550 harness is made by metra/bestkits. any bestbuy or local shop will have the standard nissan harness
Old Mar 18, 2009 | 03:17 PM
willcho415's Avatar
im buying all my supplies from best buy, they only have the nn03b one not the metra one :\
Old Mar 18, 2009 | 03:18 PM
TroysG's Avatar
sorry man the nn03b will work. I didn't realize that was a scosche wiring harness
Old Mar 18, 2009 | 03:21 PM
willcho415's Avatar
ahh, thanks so much got my worried for a sec. saw that frys had the 7550 but thats a 30min drive from my place. 30min drive just for a wiring harness!? lol
so my sub and amp will be powering okay with each other right?
Old Mar 18, 2009 | 03:59 PM
TroysG's Avatar
as long as the amp is 200 rms you should be alright, don't expect earth rattling bass though
Jusseth
Sep 13, 2020 12:25 PM
mjfenix
Aug 17, 2017 05:49 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
mushu
Jul 15, 2015 03:55 PM
