Metra 7551 harness Q, easy to A
Old Apr 8, 2009 | 10:56 PM
psycobusa's Avatar
ok, so im wiring a new HU into my 06 coupe with the bose system so i bought the metra 7551 harness. i only need to know
1 where does the blue power ant. wire go?
2 where does the black/grey amp ground go?
3 do i need to ground the black ground wire of the metra harness eventhough my HU's harnesses black wire is already connected to the chassis?
4 i have 3 other accessories for my HU that all need to be connected to a constant power source. can all 3 be connected to the same yellow wire of the metra harness?
im pretty sure these are noobie questions but its my first install. the radio shop wants 125 for the HU install then 75 a piece for the 3 accessories.
Old Apr 9, 2009 | 03:15 AM
djCypher's Avatar
#1 if the harness doesnt have one then its not used. cap it off
#2 to the black ground on the harness
#3 yes ground everything at one place. multiple grounds will cause a ground loop
#4 depending on the power drawn with each of those modules yes and no.
Old Apr 9, 2009 | 04:52 AM
psycobusa's Avatar
#4. 1 is a lockout bypass, 1 is the bluetooth adaptor, the other is a PAC swi.
the BT has a 3amp fuse, the pac has a 1amp fuse, and the lockout has none
Old Apr 9, 2009 | 11:30 AM
djCypher's Avatar
should be fine then
Old Apr 10, 2009 | 12:30 AM
psycobusa's Avatar
my radio reception was poor after install. i called metra and they said to wire the blue amp ground to the blue/white remote amp wire.
Old Apr 10, 2009 | 12:36 AM
djCypher's Avatar
you said nothing about a blue amp ground wire. you refering to the blue power ant. wire?
does the radio you put in not have a power ant. wire from the harness?
in my 16 years in car audio ive yet to see a blue amp ground wire in any harness
Old Apr 11, 2009 | 04:36 AM
psycobusa's Avatar
sorry i meant to say the blue pwr ant wire and the blue/white amp remote wire both go to the hu's blue/white amp remote wire.
Old Apr 11, 2009 | 10:08 AM
djCypher's Avatar
ya the gs have powered ants. the radio you got didnt have a dedicated power ant connection?
Old Apr 21, 2009 | 03:39 AM
the_vic's Avatar
Where do the RCA cables go?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
the93owner
Sep 28, 2015 10:37 PM
vamarris
Sep 26, 2015 12:56 PM
