Calling Car Audio Specialist...
Old Apr 12, 2009 | 06:29 PM
digitalhifinet's Avatar
A reading of "0" or so ohms indicates an open circuit...which translates to your voice coil being broken. If the subwoofer is kind of old it could quite possibly have broken due to age and not misuse or a wrong setting. When you get the new sub, if you decide to wire it up yourself, be sure you wire it correctly and set the gains on your amp correctly. SEARCH www.diymobileaudio.com for description of that kind of stuff. Its been posted and asked a million times.
Good Luck
Old Apr 12, 2009 | 06:41 PM
nchima's Avatar
Thanks guys, yea the sub is about 5 years old now...guess it was just time for a new one. Since you guys have been this helpful thus far maybe you can reccommend a sub for me. I have a HiFonics 600Watt amp, very weak. But, I don't need a sub that hits that hard, just something that hits clean, reason I only need (1) 10'
I've heard of Jl Audio, Image Dynamics....what should I look for, also would be nice if it fit in my current box. Here's the specs of the sub I have now:
Diamond Audio TDX-10D4 Car Subwoofer
Top Mounting Depth 7.52 In.
Mounting Diameter / Length 9.4 In.
Nominal Power Handling 1500 Watt RMS
Frequency Response 23 Hz - 250 Hz
Sensitivity 84 dB
Impedance 4 ohm (Dual Coil)
Thanks.
Old Apr 12, 2009 | 06:44 PM
Vrod-Mike's Avatar
I'm a JL dealer and they make great subs, but I'm also an Alpine dealer and I'll tell you that the Type R subs from Alpine are some of the best bang for the buck out there. I'm designing a system for my car right now and will be using the Alpine Type R in it.
Old Apr 12, 2009 | 06:49 PM
nchima's Avatar
Yea, I always liked alpine...reputable company.
http://cgi.ebay.com/NEW-ALPINE-SWR-1042D-CAR-10-SUB-WOOFER-SWR1042D-TYPE-R_W0QQitemZ400038855863QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item400038855863&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
would this work with my current setup?
Old Apr 12, 2009 | 06:54 PM
Vrod-Mike's Avatar
http://cgi.ebay.com/NEW-ALPINE-SWR-1...3A1%7C294%3A50
Yeah that would work fine. Do yourself a favor though and buy it from an authorized dealer. That way if you have a problem they can warranty it.
Old Apr 12, 2009 | 07:06 PM
nchima's Avatar
Okay, I'll do a little more research, but would do you recommend on the amplifier settings, I don't want to draw to much power or vice versa.
djCypher's Avatar
the box you have now is ported or sealed?
Old Apr 12, 2009 | 07:11 PM
nchima's Avatar
either/or...but, it's sealed to my knowledge. Has an opening on the side...sorry for being kind of vague.
Old Apr 12, 2009 | 07:28 PM
djCypher's Avatar
that will change the box size for that sub and might change the choice of the sub to replace it with. try taking a pic of it if you can
most diamond subs are .7-.8 cuft sealed
ported 1.00 - 1.25 cuft
Old Apr 13, 2009 | 12:15 AM
nchima's Avatar
Alright, will post pics of box tomorrow. Thanks.
Old Apr 13, 2009 | 10:33 PM
nchima's Avatar
Old Apr 13, 2009 | 11:20 PM
Vrod-Mike's Avatar
That looks like a pre-made ported box. The Alpine would work fine in a box that size if you go that route.
Old Apr 13, 2009 | 11:26 PM
nchima's Avatar
Very nice, I'll be ordering that Alpine Type R by the end of the week, as soon as I get over this illness and deposit my monies...Thanks, and will post pics of new sub when it comes in.
Old Apr 14, 2009 | 01:20 AM
djCypher's Avatar
looks like it would work if the diamond sounded good in there before. however if you had a custom box made for the sub your getting it would out perform the prefab you have now. just an idea for down the road
chinee
Jun 10, 2024 07:48 PM
vmcarbuyer
Oct 12, 2019 12:42 PM
mjfenix
Aug 17, 2017 05:49 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
