a couple questions, hope you can help!!!
Old Apr 29, 2009 | 07:14 PM
WhiteHeadTurner's Avatar
I have a G35 coupe. W/ navigation.
I got the pioneer avh-p4100dvd
And also got the adapter harness off clutchfield.
Now here are my questions.
1. I have an automatic tranny. I need to connect my light green wire to my parking break. How and were?
2. I heard I needed to connect a speed sensative wire or something like that for my navigation to work.
Huh!? That's not in the instructions, anyone have a 101 for me?
3. My pioneer harness blue wire, is "connect to system control terminal of the power amp or auto-antenna relay control terminal" now on my adapter harness I have 2 blue wires one is for "power antenna" the other "amplifier turn-on". Which goes to the pioneer, or is it both??
4. Black wire off adapter says "connect to chassis of new receiver" amplifier shield ground. So I need it? Were do I connect it?my pioneer harness has a black grounding wire I've already grounded.?
5. I have the pac, swi-ps, used for useing the steering wheel buttons. The previous owner told me to change 3 relays. I don't speak Arab lol. WTF! It has 3 wires black red white. Were do they go, and what relays?
6. How do I bypass so my DVD can work while the car moves, and navigation to IF possible??
Now please refrain from leaving negative comments. If you can help please type it out. I really would appreciat it.
And don't tell me to go to a mechanic .
I like to try things out. Ok I'm lost but with your help n if I get it done I'll be very happy, I'm sure many off you understand
Well thanks again, and I'm in my car right now. Messing with it.
Old Apr 29, 2009 | 10:38 PM
TroysG's Avatar
my friend.... this is NOT a car to learn on.
this is one of the biggest pain in the *** cars for an installer to work on. I'd say if you are unfamiliar with anything about the install take it to a car audio shop - I didn't tell you to take it to a mechanic
but if you're strapped for cash. the easiest thing to do is.... SEARCH
parking brake - you have to connect to the wire at your lil foot brake thing you auto drivers have. If you don't know how to test for continuity... search I just posted it recently.
blue/white on deck - I've posted on this prolly 100 times blue white goes to blue and if you want the blue/white on aftermarket harness doesn't make a difference really as long as it goes to the power antenna wire
That deck doesn't do nav genius speed sensor wire isn't a concern.
connect black wire from deck to chassis ground... don't worry about the ground in aftermarket harness. it's a bad ground anyways
steering wheel controls... go to PAC website print out directions. - MASSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSIVE pain in the *** to program good luck read instructions 4-5 times keep instructions with you when programming.
viewing video while driving... I'm not telling.
Old Apr 29, 2009 | 11:52 PM
Gr8speed68's Avatar
Ya im not installing my own noway it's a big pain!!
Old Apr 30, 2009 | 12:42 AM
got it all to work ,
but im getting no video.
i get sound. but no dvd video or iphone video.
Muski_G
Dec 1, 2023 11:11 AM
leo38cheng
Aug 17, 2015 12:16 AM
si_driver
Aug 11, 2015 07:08 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
