Upgrades to Bose - Replace subs
Old Jul 9, 2004 | 02:08 PM
JimHarrison's Avatar
My goal is to upgrade the bass from from OEM Bose system. As an alternative to adding an Infinty Basslink, I've read that a good 6X9 sub is available as a replacement for the Bose 6X9 speaker (and is surprisingly cheap). However, I've also heard people complain about the lack of highs. Could I consider, replacing the 6X9's with a good quality 3 way speaker like the Infinty Kappa 693.5i or the JBL P953?
I know little about the Bose amp. I believe it only powers the subs. Does anyone know if it has a built in cross-over in it or is it a full range amp? If the latter, I wouldn't have to replace the stock amp.
Jim Harrison
04 G35c 6MT Desert sand
jharrison@manapp.com
Old Jul 9, 2004 | 05:43 PM
justICE's Avatar
Re: Upgrades to Bose - Replace subs
It powers all the speakers. It is really a very poor amp though. I have heard the stock amp with very good seperates and it just doesn't cut it. Clarity is just not there.
-JustICE
Old Aug 28, 2004 | 01:40 AM
realgone's Avatar
Widdle ya into kindling
Bose runs at something like one ohm and is only compatable with bose speakers anything else will work,but sound like crap.
Old Aug 28, 2004 | 11:18 AM
djrobx's Avatar
See the stock values thread. The tweeters measured at 4 ohm and the 6"'ers are measured at 2 with an ohmmeter (however, "nominal impedance" values are different ... a bit higher, than what you'd read with an ohmmeter).
So, you should be able to get away with just replacing the stock tweeters. You can do the 6" too, it just might become a bit quieter. I definitely suggest removing the Bose amp and replacing it with your own, though. It's pretty easy to do because the all wiring (except the battery, of course) is right there conveniently in the trunk.
I'm not sure whether the Bose amp actively powers all the speakers or just the sub. Infiniti does run everything *through* the amp, although the input to the amp is a full speaker-level signal from the radio. It's certainly possible that they just let the head unit power some of the speakers (perhaps with a crossover) and let Bose amp power the subs. One of these days I should crack open my probably-never-to-be-used again Bose amp and see what's in there.
EnCr1pt3d
Jul 8, 2019 02:48 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Frostbite91
Aug 2, 2015 04:59 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
