fuses
Old May 6, 2009 | 11:11 AM
arniesalas's Avatar
fuses
ok I screwed up big time I am still having problems with my ac it's still on and no control of the stereo. I have spoken with someone who fixes this problem and I am going to get it fixed. Here is the problem now I pulled some fuses and now my control for my garage opener, and the clock and turn signals are not working. Does anyone know what fuses I need to replace or put in correct place?
Old May 6, 2009 | 11:25 AM
nr2d's Avatar
I may sound a little abrupt BUT it might help to read your owners manual. It has a diagram of the fuses and their function. Just remember that there may be blank spots on the fuse panel. This sounds like the problem. You may have pulled the fuses but reinstalled them in the wrong spots.
As to your other problem I had a similar problem with my '08 sedan. The entire center console went out, no ac/heat, no nav/radio control. It looked like the main computer died. After about 15 minutes the computer rebooted and everything was fine. I did how ever tell my dealer about the problem on my next service visit. They saw a trouble code that stated a communications problem. They reseated all of the connectors and I have not had ant problems since (Knock on wood, fingers crossed).
Old May 6, 2009 | 11:41 AM
arniesalas's Avatar
Thanks, I have looked at my manual but I have a hard time seeing it because of my eyesight. That may be the problem. I will bring out the magnifying glass.
Old May 6, 2009 | 11:56 AM
arniesalas's Avatar
ok I looked at the owner's manual and there is no diagram for fuses on pages 8-20 thru 8-23 this is where they talk about fuses.
Old May 6, 2009 | 11:57 AM
Darkchyle20's Avatar
The A/C and radio fuse is 15A. If you go under your hood next to the battery, you will see your fuse box (easy to get too if you remove the panel). You will see a fuse 15 in between 2 10 fuses. That is for your radio / A/C.
G35-R
Nov 7, 2015 01:21 PM
Learned Hand
Oct 1, 2015 09:02 AM
yosip1115
16
Sep 28, 2015 04:14 PM
JLee301
Sep 25, 2015 08:46 PM
2014g35x
Sep 11, 2015 07:53 PM
