HELP testing Alpine w505 Double Din/ Navi
Old May 9, 2009 | 11:35 PM
ea_rsx's Avatar
Hey guys
I am picking up a used Alpine w505 double din and navigation. It is not installed and I want to make sure everything works before I buy it. I have Googled this and it says to hook up the red and white to positive battery terminal and black to the negitive terminal. Is this true? If so can I test all full functions with buy doing this or is there something else i need to do?
Also does anyone have this deck and like it or dislike it?
need help let me know.
Thanks
Daniel
(ea_rsx)
Old May 10, 2009 | 01:38 AM
PeterUbers's Avatar
I test "drove" the Alpines at the Abt where i bought my Kenwoods (i have the 6140 and the 8120) .. can't say I was a fan -- didn't like that navi cartridge dealie you have to put in there for the navi to work ... I thought the Kenwood was more intuitive, just my 2 cents.
well -- if you REALLY want to test it .. you should test all four speaker outputs -- therefore you'll need to connect more than the just the red, yellow, and black wires (ACC, constant battery, ground).
I supposed you can just provide 12 volts to the red and yellow wires and ground the black and get the unit running so you can play with the touchscreen and see if it'll switch functions etc...
Old May 10, 2009 | 07:47 AM
TroysG's Avatar
if you have a speaker laying around that's working you can connect that to white white/black, then the grey grey/black, purple purple/black, green green/black
test with a cd or anything but the radio as you likely won't get a signal
Old May 10, 2009 | 10:14 AM
G35 Mass's Avatar
I had an alpine deck about 5 years ago, and it would not power up without the antenna being plugged into it.
Old May 10, 2009 | 11:04 AM
TroysG's Avatar
^^^that's due to it not being grounded completely
Old May 10, 2009 | 07:09 PM
ea_rsx's Avatar
Thanks a bunch buys I will try these ideas out hopefully it powers up.
Has anyone else had any issues with this deck (lover or hate it)?
Old May 11, 2009 | 12:01 AM
TroysG's Avatar
I REALLLY wanted it for it's sound processor but couldn't afford it, and I had just bought the kenwood 8019
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BfloG35
Oct 16, 2015 05:22 PM
TurTLe*
Sep 29, 2015 01:43 PM
