advice from thoes with Aftermarket HU
Old Jul 13, 2004 | 03:32 PM
brands306's Avatar
I just bought a KVT-911 for my wifes car i installed one in my truck and love it it was plug and play i bought a plug in harrnes and it was easy....
Will it be as easy in the g or do i need out side help i just ordered the double din kit ....
what harness are you guys using can i buy it at a local stero shop??...
whats needed to get clear FM/AM ??....
Any help guy and if any one in the miami area want to help ill buy the beer and pop in a little girls gone wild after the install is done!!!
Thanks Brandon
Old Jul 14, 2004 | 12:56 PM
RamboRami's Avatar
G35driver.com Moderator
Re: advice from thoes with Aftermarket HU
1) Its easy if you know how to plug wires together, read the DIY/FAQ and see if you can do what it says (its not that tough)
2) You will need 2 harnesses and 1 antenna adapter. The harnesses are Scosche NN03 (2 come in 1 package) and the Antenna adapter is the standard Nissan antenna Y-adapter (1996+) forgot the model #
3) To get clear radio reception you will need to connect the Power antenna wire from your headunit into the harness or the car's green/white wire #5.
Good luck!
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Old Jan 5, 2005 | 11:28 PM
chisox_23's Avatar
hey ramborami,
could you be a little more specific on the power ant hookup to my aftermarket unit.
i got the eclipse avn unit and now my fm reception sucks.
any suggestions
or could you point me in the right direction.
i searched the forums and some hyper-linked threads did not work on this site.
thanks in advance for your help.
peace
sam
jeffbdye
Jun 1, 2018 03:51 PM
Fox843
Nov 7, 2015 05:43 PM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
