Hiding 1/0 or 0 gauge amp power
Old May 26, 2009 | 11:00 AM
wdgolden's Avatar
I've seen how to run 4 gauge power wire from the battery to the rear. I plan on running 1500+W total so I'll need at least 1/0 gauge power wire. Does anyone have tips on running this from the battery to the trunk? Someone mentioned running it underneath the car instead of through the cabin but I'm not sure how I feel about that even if it is shielded.
Old May 26, 2009 | 02:38 PM
TroysG's Avatar
I ran 0 gauge... surprisingly easy... take your time though. What I did was drill a hole in behind the battery, and just fed it on the passenger side taking advantage of every nook and cranny I could find.
but you can't tell I've got 0 gauge in the car at all
Old May 26, 2009 | 02:46 PM
imaginag35's Avatar
^^^ yeah,take your time and do it correct.I'm rumming 0 gauge also and it's all hidden inside and under things..not under the car..
Old May 26, 2009 | 03:33 PM
wdgolden's Avatar
Is there enough room under the carpet and door sills for the 0 gauge or did you run it some other way?
Any way you could take some pictures of it?
Thanks
Old May 26, 2009 | 04:07 PM
TroysG's Avatar
can't take pics... too hidden. but it's not hard. drill hole - make sure you don't drill into anything important. if you have a grommet big enough USE IT! then take up the carpet on passenger side. I think there were metal braces I went through. and just continue feeding it back. and between the trunk and backseat there's a nice brace that leaves a pretty big gap. I put my distribution block on the passenger side underneath the plastic place holder, and fed 4 gauge to each of my amps - couldn't find 2 gauge :S
Old May 26, 2009 | 09:52 PM
wdgolden's Avatar
Cool, from what you're saying I can completely hide 0 gauge wire underneath the door sill. Did you have to do any modifications to the carpet/door sill or was there enough room for the cable?
Old May 27, 2009 | 08:51 AM
TroysG's Avatar
nope. and it's not quite the door sill it's just inside the lip. I can't remember at the moment but you might end up with a slight bump going up to the rear seats.
sorry man forgot to ask coupe or sedan. I have a coupe may be COMPLETELY different than the sedan
Old May 27, 2009 | 09:11 AM
ttrank's Avatar
Grocery getter
+1
I did the exact same thing. I was an audio installer for a few years at a high end shop working on all makes/models and this was one of the easier ones to run 1/0 wire.
Old May 27, 2009 | 09:32 AM
blazeplacid's Avatar
you can run 0 though the rubber grommet behind the battery location
ALOT of room under the carpet to hide wire
I have 0ga,2 pairs of rca, and another 4 ga wire
no bumpor anything showing
Old May 27, 2009 | 09:36 AM
ttrank's Avatar
Grocery getter
That's another option too. I just didn't like the bend angle so I went straight.
Old May 27, 2009 | 09:43 AM
true, but almost any 0ga will bend quite a bit
the "myth" that 0ga is impossible to bend is just that, a myth
Rockford/Kicker/Stinger wire is a bit more flexable but even the cheap stuff bends easy
Old May 28, 2009 | 11:19 AM
lancer's Avatar
*sigh*
How many Amperes will you be running... wattage "ratings" won't tell you much.
<= 150A ... 4awg
http://www.wescomponents.com/datashe...e_by_power.htm
Old May 28, 2009 | 11:38 AM
TroysG's Avatar
^^^ good find man
in order to find the current you're drawing easiest thing to do is add up the fuse ratings on the side of the amp(s)
Old May 28, 2009 | 02:08 PM
wdgolden's Avatar
I'd prefer to err on the side of caution.
I'll have one JL 450v2/4 running mids and highs and then whatever will be required to properly power 2 IDMAX 10" or 2 JL 10W7. The IDMAX are rated to 1000W rms and I believe the JL are up to 750W rms. I'll have to find a decent 1500W amp to run both, maybe a Rockford T1500? I haven't checked into sub amps for a while so I'm not sure who makes a solid product that actually outputs the rated watts.
With winding the cable through the car I'm figuring more than 6 meters of cable which puts me closer to 2 gauge and I've found 1/0 easier than 2 gauge.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
Danielek
Sep 10, 2015 06:18 PM
zcherub
Sep 10, 2015 12:03 PM
