Help!!! Xbox with Nav-Tuner
Old Jul 15, 2004 | 07:36 PM
paintballbitch's Avatar
Hi all
I tried to install my Xbox to the Nav-Tuner... when I booted up the color is black & white... I have tried to switch the AV input with my DVD player, but it is still black and white where as the DVD player is displaying Full Color Mode....
I have tried to use power outlet from my home and still the same result....
Does anyone have any idea?
Thanks!!!
G35c, 5AT, NAV
INJEN CAI, Borla TD Exhaust, Grounding Kit
Kinetix Plenum, Hi-Flow CAT, Front Lip Spoiler
8000K HID, PIAA 7500K SPARK BLUE
Focal 165K2P, E10A.22, Eclipse HU, Nav-Tuner
Old Jul 15, 2004 | 07:55 PM
dirty_sanchangz's Avatar
Re: Help!!! Xbox with Nav-Tuner
check the cable?
Old Jul 15, 2004 | 08:05 PM
I did, I have tried to use 2 different cables already...
G35c, 5AT, NAV
Old Jul 15, 2004 | 10:46 PM
what kind of cable are you using composite, component?
Old Jul 15, 2004 | 10:48 PM
you can try unpluging each section to check each connection, also try hooking your xbox to a regular TV to determine if it's the xbox that's making it black and white. I know sometimes my friends xbox does this, we just make sure the large connection to the xbox is secure.
Old Jul 16, 2004 | 10:04 AM
I am using composite and I have tried to plug into my TV already... and with the TV, it works fine....
G35c, 5AT, NAV
CKwik
Jun 24, 2005 10:39 PM
MAZyar
Jun 23, 2005 05:47 PM
