How can i cut down on rattling
Old Jun 18, 2009 | 03:49 PM
infiniti g's Avatar
I have an 03 sedan with a Pioneer DEH P6000UB, 2 12" RF punch P2s powered by a 1000 watt amp. I understand you cant completely stop the rattling, but i just want to cut it down. Everytime the bass hits the whole deck behind the back seats rattle really loud and rom outside my trunk is extremely loud. Right now i have a rag in between the third brake light and the back window which helps but hthat is only temporary. I have a ported box would it help if a had a closed box? I plan on getting a smaller box. What are your recomendations.
Old Jun 18, 2009 | 04:05 PM
EldinsG35's Avatar
When I had my Acura Cl Type S and was heavy into sound and DBA drags, I used a product called Edead V2. It is fairly cheap as appose to Dynamat and very easy to work with. Hope that helps.
Old Jun 18, 2009 | 04:09 PM
PeterUbers's Avatar
what's up with the alignment of your trunk in that first pic at the top??
Old Jun 18, 2009 | 04:38 PM
GR6RR's Avatar
^ didnt even notice til you said something, looks like it is uneven, lifted on the passenger side..
back to the rattling, in my car, most of my rattle come from where the roof liner meets the top of the back window, i folded some CD album booklets and stuffed it in there, stopped most of my rattling from the inside. also for the out side, i put a couple of layers of 3M tape holding the plate to the frame, and then more 3M tape for the plateandframe-to the car... a cheap fix it...
Old Jun 18, 2009 | 04:53 PM
infiniti g's Avatar
Thanks for the advice. How much do you recommend buying and would it be easy for me to install, the only things i have done myself since i have had it is installing the system and taking the reverse lights out. If I line the trunk with this stuff will it cut down on the trunk rattling on the outside and improve bass quality?
Thanks
Yea i noticed that the other day too i not sure what it is. It sits about 2-3 cm above the otherside i havent looked at it closely yet but i will soon. Im not sure what it would be though.
Old Jun 19, 2009 | 04:22 PM
blazeplacid's Avatar
please do not use edead of any kind
done use edead v1,v2se, 80mil
use second skin or dynamat xtreme
both are superior to anything else
yes they cost more but they are worth it
and yes I have used almsot every deadner
Old Jun 20, 2009 | 02:27 PM
infiniti g's Avatar
O ok. but i dont need anything amazing i just need something that will work. what do u think is the best material for the best price
Old Jun 21, 2009 | 01:44 PM
infiniti g's Avatar
Well i looked at the trunk alignment. It turns out that there was a bolt loose, i tightened it and now the trunk looks normal again.
Thebaws11
Jul 2, 2021 11:36 AM
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
JustinMKN1
Sep 18, 2015 03:40 PM
