Q: Bose amp by-pass harness 06 coupe premium
Old Jun 28, 2009 | 09:03 PM
SWANLOVE's Avatar
Hi Everyone,
I have 06 coupe 6MT w/premium pkg and want to upgrade the sound system.
First I am attacking to swap out bose amp with Alpine. I searched the forum pretty thoroughly to find a by-pass harness for bose amp (blue connector) and found this Metra 70-2003 from the following thread. It looks like it's for sedan.
https://g35driver.com/forums/audio-v...6k-beware.html
But when I tried to hook it up, it didn't go in. I hoped the harnesses for sedan and coupe are same but obviously they are not.
So I am out searching for the harness again and I'd like to ask your help.
Does anybody know which harness I should buy?
Thank you in advance.
Attached Thumbnails Q: Bose amp by-pass harness 06 coupe premium-p6280432.jpg   Q: Bose amp by-pass harness 06 coupe premium-p6280433.jpg
Old Jun 28, 2009 | 10:28 PM
TroysG's Avatar
ya the 70-2003 is a GM harness, so it definitely will NOT work on a nissan/infiniti
I'd recomend - until you put an after amp and speakers in utilize the bose amp it makes a HUGE difference just by changing the head unit.
pick up Metra 70-7550 harness. you won't have any issues. it plugs into the original harness and you just have to solder the wires from the aftermarket deck to that one.
*note to turn on the Bose amp you must connect the blue wire from the 70-7550 to either the blue/white OR red wire
Old Jun 30, 2009 | 01:02 AM
06g35ca's Avatar
I am using the 70-2003 on my 06 couple. The pins match up. However, the slots in the 70-2003 do not. You will have to cut two slots on the 70-2003 to be able to plug the connector in.
Old Jun 30, 2009 | 10:41 AM
TroysG's Avatar
sorry but as soon as you have to modify a harness to make it work it's NOT worth it
Old Jun 30, 2009 | 02:42 PM
06g35ca's Avatar
You don't modify your harness. You just need to break off the plastic part of the Metra 70-2003
The two center slots on the metra don't align with the nissan harness
Just break it off and you can plug the connector in
Old Jul 2, 2009 | 12:06 AM
SWANLOVE's Avatar
I guess 06g35ca meant breaking off the plastic part of the "blue connector"? I don't see any center slots on Metra 70-2003. Besides, I thought "blue connector" was a lot thicker than Metra. Maybe I was mistaken.
I wish you chimed in two days sooner. I went ahead with the installation last two days. I couldn't pick better day to do it. Almost 105 deg outside both days.
What I did was to pull out all enough pins from Metra, wrap with shrink tube, solder extension wire to amp and construct a very very crude wiring harness. I tiewrapped it to existing wiring harnesses with cable ties so that it won't come off with vibration and movement.
Anyway, everything works fine and sounds a lot better than stock bose amp. Oh I added subwoofer too with 4080 box. Here is what I added:
Alphine MRV-F450 (old. I recycled from my old car)
Sub JL AUDIO 10W3V2-D2
4080 Box
Next is to replace with front and rear speaker with DLS or MB Quart.
I will try to post some pictures later
Thank you for posting comments and help. I appreciate it.
mjfenix
Aug 17, 2017 05:49 AM
Frostbite91
Aug 2, 2015 04:59 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
vstypicals
Jul 20, 2015 10:55 PM
