sub dont work
Old Jul 3, 2009 | 12:29 PM
gthirtyfizzzle's Avatar
sub dont work
i just got my sub installed with a factory radio and on the way home it just stopped working when i opened the trunk i saw the amp light was still on and check the fuse on the amp it was good check all the connections they were nice and tight buy when i look at the sub i noticed that it had a tear along the outside about 1/2 long is this enough to not make the sub work at all???? i figured it would hit but just sound like crap
any suggestions???
Old Jul 3, 2009 | 08:03 PM
any help??
Old Jul 3, 2009 | 08:34 PM
Vrod-Mike's Avatar
The tear won't stop it from moving so that's not the problem. Like you said it would still work, but sound like crap.p is still turning on then either it's going into protection mode and shutting the outputs down or there's a problem with the inputs. I would bring it back to the place that did the install and let them fix it.
Old Jul 4, 2009 | 10:48 AM
TroysG's Avatar
can you still push the cone in? if you can't then you're blown the sub and frozen the voicecoil.
Old Jul 5, 2009 | 02:40 AM
Gu3s5who's Avatar
Mine are doing the same thing. How do I know if they are going into protection mode?
Old Jul 5, 2009 | 10:49 AM
TroysG's Avatar
what amp do you have?
most amps have a small light and somewhere close to the light it says protections. most likely it will be a red light that's on
Old Jul 6, 2009 | 10:51 AM
it is a koiiler amp and i do not see any protection light
Old Jul 7, 2009 | 01:18 PM
going to the place that installed it tommorow i have feeling the amp is shot
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
JMSABO
Aug 4, 2015 11:58 AM
attarday
Jul 15, 2015 04:03 PM
