PLEASE HELP...Check engine light came on after installing PAC AAI-NIS2
Old Jul 18, 2009 | 01:26 PM
mikeee2's Avatar
Hi,
I installed the PAC AAI-NIS2 today and the Aux1 and Aux2 works. After I put everything back together, started the car and I had a "service engine light". Then I realized when I put the shifter back on that I didn't insert it through the plastic bracket underneath so I wasn't able to pull it down to D and it stops at N. Not sure if that has anything to do with it. Then I took out the console and fixed it. Engine light was off. Then I tighten the negative battery in thinking everything is fixed and when I started engine again the engine light came back on again. The two connectors under the shifter is connected and I am not sure what is triggering the check engine. Can someone please help. I even tighten the gas cap just for the heck of it. Everything is working, radio, ac, shifting gears.
When I installed the PAC AAI-NIS2, I had to shift it to N and when I do that I can't get the key out so I am not sure if that has anything to do with it. The Neg battery is disconnected while I setup the PAC AAI-NIS2.
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 18, 2009 | 07:40 PM
orion71483's Avatar
Did you disconnect the air bag on the passanger side while the battery was still connnected?
Old Jul 18, 2009 | 10:46 PM
mikeee2's Avatar
Where is the air bag plug?
Anyway, I took the console area off, unplug and plugged back in the two plugs (I think one is for the shift indicator and the other one is probably link to the a/t shifter. Then I wiggle the PAC-AAI-NIS2 around hoping it would do something. Then fire up the engine and the "check engine light" is GONE and all is good.
Old Jul 20, 2009 | 04:17 PM
ttrank's Avatar
Grocery getter
Air bag issue would give you a solid or flashing airbag light, not a check engine.
Old Oct 18, 2009 | 07:37 PM
myC17isfaster's Avatar
I had the same thing happen to me today but I think it's because the car was in D when I reconnected the negative battery terminal. It should go away in a matter of a few days.
For my own comfort, you havent had any problems / check engine light incidents since then ... have you?
thanks
Old Oct 18, 2009 | 09:08 PM
mikeee2's Avatar
thanks
No, it didn't come back on. After I took off the console and put it back together it was all good. I am not sure if it goes away automatically though.
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
