Navi doesn't work after "professional" HU install!
Old Aug 11, 2009 | 09:43 PM
Bucszilla's Avatar
I just got back from having my new HU installed and the guy at the audio place told me they "couldn't get the navigation to work but did not call me because they assumed I knew already" ...WTF?
The navi screen pops up when I start the car but goes back down...the screen is black and is not getting power. What do I do??
I need some help badly!
Where can I find the navi wiring diagrams? I just think this guy doesn't know what he's doing but I am freaking out right now!
Old Aug 11, 2009 | 09:51 PM
I ride G's Avatar
navi should work, i've seen it done before. only thing is you need to add a tweeter for the navi voice cuz it doesnt work with aftermarket hu
Old Aug 11, 2009 | 09:56 PM
Bucszilla's Avatar
At this point, I do not care about the navi voice...I just want the navi to power on.
What should I do? The installer said that he couldn't get the nav to work and it "must be tied into the factory HU"
Why me?! Help!
Old Aug 11, 2009 | 09:57 PM
I ride G's Avatar
lol im actually kind of in the same boat as you. except my navi turns on, just the buttons dont work!
Old Aug 11, 2009 | 10:06 PM
Bucszilla's Avatar
Can someone help us out please...
A navigation wiring diagram would do wonders!! I cannot seem to find one anywhere...
Old Aug 12, 2009 | 03:59 AM
Hurt_Locker's Avatar
I have no idea what G you have but as a guess, here are the coupe Sevice Manuals. Should have all the diagrams you need. The shop most likely left something unplugged. I would start by verifying all connections are made first, you are gonna have to pretty much remove the panels and the HU to check continuity and voltages anyhow. General rule of thumb is start simple.
Coupe Sevice Manuals
Old Aug 12, 2009 | 11:48 AM
Bucszilla's Avatar
I appreciate all the help...the only is that I need the 06 sedan wiring diagram.
I am at the audio shop now and they are basically trying to wire the power to each harness that connected to the navi and go from there.
If anyone could post the schematics to the 06 I would def be indebted to you...
Thank you for any help!
Old Aug 12, 2009 | 12:03 PM
suicidesam's Avatar
****defected****
Navi doesn't work after "Non-professional" HU install!
I fixed your title for you...
Old Aug 12, 2009 | 12:12 PM
jwrape's Avatar
Sounds like you are having the same issue I am, the screen will pop up and then go back down. I have been able to get mine to work twice in the week and a half I have owned my G, one of those was this morning.
I posted here and got an idea of what's wrong.
https://g35driver.com/forums/audio-v...t-stay-up.html
Old Aug 12, 2009 | 09:50 PM
Bucszilla's Avatar
Everything eventually came out ok...the guy just needed to reset the nav simply by disengaging the grey wire harness. After that he just had to tweak the placement of the nav and ac control panels so the nav could come completely down.
jwrape, your nav probably isn't coming down all the way or something is blocking it from coming up completely. When that happens, the nav screen will not stay up/down...
The problem I am having now is the Alpine MRP 1000 watt amp is overheating after about five minutes at a time! LMAO...this install has been a nightmare and will forever be etched in memory!!!
Do I just return this amp to Crutchfield and get a PDX?
Old Aug 12, 2009 | 10:10 PM
I had similar issues with a Kenwood Excelon 1200D sub amp I had. It was rated at 1 ohm stable but wired 1 ohm it would work for about an hour and the amp would die. Come on and not even go into protect mode, just power light on and nothing. On the 3rd amp they gave (I had given up on Kenwood but it was the best option at the time) I took the remote base **** wire that I had installed in the car for my other MTX amp and used the supplied Kenwood cable. Apparently not all cables are the same even though the **** worked for the first two. That fixed the issue, that or I got a good amp finally. Overheating that fast is a sign of something not hooked up correctly. If the shop did the install I would ask them about it and maybe they will replace. If not def back to Crutchfield.
Old Aug 12, 2009 | 10:51 PM
Bucszilla's Avatar
I went out to listen in my garage and now I think the sub is blown
It still hits a little but it has a distinct crackle sound when the bass note hits a certain freq.
This is getting exhausting...
Old Aug 13, 2009 | 09:10 AM
Yea might wanna ohm that out and if it is blown remove it from the system quickly as it can take the amp with it at any time. Can also shorten its life span. It may still work for the most part but the resistance on that sub can be changing drastically through the excursion, can be harmful for the amp.
Old Aug 13, 2009 | 09:49 AM
Bucszilla's Avatar
Good call HL, thanks...
As for the sub, I guess it's back to the drawing board *sigh*
I really want to send the amp AND sub back to Crutchfield...has anyone returned an item that is broken (ie blown sub)?
Old Aug 13, 2009 | 12:20 PM
rcdash's Avatar
The problems could be related. If it's within the return period, Crutchfield won't give you any trouble. I think they pay for return shipping even...
chinee
Jun 10, 2024 07:48 PM
newg37
Jul 26, 2015 09:32 AM
attarday
Jul 15, 2015 04:03 PM
