Climate Control Not Working **HELP**
Old Aug 26, 2009 | 12:20 PM
rayray123's Avatar
Now i know there are several posts about climate controls not working right, but i think my situation is a little more unique
so i had this problem for a while now
so i did the usual, have it checked out with ifiniti who told me it was a burnt out circuit board, so i got the metra double din kit and put a double din radio in.
I thought that would solve the problem but the problem was still there, the radio worked fine but the climate controls would stay on,
so i called metra who told me to see if they're any jumpers on the metra circuit board, i checked that and there are none
i also checked the connection/rubber tube under the steering wheel and that seems fine too
now sometimes my climate controls are normal and while i'm driving they'll just turn on, on there own and the problem starts again, and then after a while they'll work again, and back and forth
HELP ME PLEASE
Old Aug 27, 2009 | 12:53 PM
Knights's Avatar
no one is helping on this subject?
Old Aug 27, 2009 | 07:48 PM
stuiees's Avatar
i just started having the same problem with my double din kit... air will go on auto climate so it turns on full blast. after i turn the engine off it will then go back to manual control. not only that, my temp control doesnt work and seems to be stuck at 75 degrees. sucks on these hot so cal days
Old Aug 28, 2009 | 08:31 PM
naughty240's Avatar
my guess would have been that rubber hose thing with that harness. I had forgotten to plug that in twice.
Old Aug 30, 2009 | 11:02 AM
rayray123's Avatar
ok so the wife had a suggestion that the ac comes on when the interior temperture is hotter than the temperture on the climate control
and once the car cools down, i then have control over the climate control
what could cause this and what can i do?
Old Dec 11, 2009 | 03:54 AM
V35iam's Avatar
i have the same problem. i wanted to get a DD deck hoping the problem will go away, but it seems like you are still having that problem with the auto AC. I changed out the face plate (climate control circuit board) but it wasn't it. The dealership wants $450 plus tax in exchanged for your broken one for their repairable stereo. If i am going to spend a lot of money on a DD, then i hope the problem goes away. Did you ever fix the problem?
arora_g35
Apr 16, 2026 02:52 PM
rezendvous420
May 31, 2020 01:26 PM
WillisFL
Dec 29, 2016 08:56 AM
kd03g99
Jul 30, 2015 11:24 AM
