radio goes in and out
Old Sep 3, 2009 | 12:19 PM
radro's Avatar
Cool radio goes in and out
on my radio sometimes the sound randomly gets cut off and comes back on seconds later does anyone know y this happens. I drive a 2004 g35 coupe 6mt
Old Sep 3, 2009 | 12:36 PM
jwrape's Avatar
poor reception, we all have that problem....POS antenna
Old Sep 3, 2009 | 03:39 PM
radro's Avatar
cd player
my cd player does it to though think it might b bad wiring?
Old Sep 3, 2009 | 05:30 PM
nghiars's Avatar
i know with the 1st gen g35s, the circuit board in the radio/ac buttons have shorted few.
Old Sep 4, 2009 | 10:34 AM
radro's Avatar
So I have to get a new radio?
Old Sep 4, 2009 | 11:07 AM
Mike_Deezy's Avatar
Are you talking about satellite radio? If you are, I have the same problem with both my vehicles. It has a tendancy to go out if there's something obstructing the signal's path to the satellite.
Old Jul 20, 2021 | 03:16 PM
Mike1650's Avatar
I've read most if not all posts regarding the stock radio with the bose system. I cannot get more than one fm station and 0 am. Where are all the connections for the antenna located in first model 2003 g35 sedan? Im thinking antenna connection because it does not seem to be electrical problem. Anyone? Thanks
Update. I got the radio repaired here in Rancho Cordova, CA . It was the tuner box itself that was causing the problem. Not cheap at $225 but it now works. The tuner box itself is like 4x3x1/2 in thick.
Old Jul 20, 2021 | 06:30 PM
telcoman's Avatar
Veteran: Army
Is the AM and FM radio antenna built into the windshield?
Old Jul 20, 2021 | 07:01 PM
Mike1650's Avatar
2003 sedan, back window, stock bose system, no mods
Old Jul 20, 2021 | 08:04 PM
telcoman's Avatar
Veteran: Army
Have you checked out the FSM?
https://www.nicoclub.com/service-man...F2003%2Fav.pdf
See page AV-39
https://www.nicoclub.com/service-man...F2003%2Fgw.pdf
GW-124
Good luck
Old Jul 21, 2021 | 11:53 AM
Mike1650's Avatar
Originally Posted by telcoman
I saw FSM and I have sunroof model. I truly think it is the antenna cable connection at the head unit. Is there any shortcut to checking the head unit connection without taking the console out. I had it done to fix the AC problem in these and maybe at that point there was a loose connection that has since come loose. One more, If I get this repaired any idea what an original owner, Premium, NAV, sunroof, 2wd sedan Winter package sedan would sell for with 51600 miles. Thanks for your input here.
Old Jul 22, 2021 | 12:10 AM
iNFiИiTi's Avatar
G35 with cold air intake, air suspension, 19" wheels, 2500w dual chan amp and 12" sub, aftermarket
11-13k would be my guess
Old Jul 22, 2021 | 12:52 AM
Mike1650's Avatar
Sounds good. Should I post here on classifieds?
Old Jul 23, 2021 | 03:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The antenna is built into the rear glass.
sck2000e
Feb 3, 2018 11:20 AM
KwickG35
DFW G35 Owners Club
12
Aug 26, 2009 04:15 PM
broker99
Aug 1, 2009 05:49 AM
andy2812
Jan 27, 2007 10:55 PM
