4080 box installed
Old Aug 7, 2004 | 03:42 AM
xswl0931's Avatar
4080 box installed
Got my 4080 subwoofer box installed. The box itself is well designed. The thing that sold me was how easily you can install/remove it, how nicely it fits on the side, support for the cargo net and works with the trunk mat in place. I ordered it with the grill and carpet. There were some minor carpeting fitment issues, but it was all on the back side which wasn't visible, so no big deal.
I did the install myself which took longer than expected due to hiding all the wires. I used a Kicker Solobaric S10c that I had in an old box I used in my Pathfinder (the box wouldn't fit in the G35c) and my old MTX 280 amp. Thanks to all the articles on this board, I went through the firewall by poking a small hole in the grommet that's behind the battery and drops directly into the passenger side. Ran the power wire under the passenger carpet, under the rear seat into the trunk. Ran the speaker wires under the driver seat to the trunk. I installed the amp on top of the Bose amp in the trunk. Two of the holes for the amp fit perfectly on top of the Bose metal bracket. Tapped into the blue/silver wire of the Bose amp for the remote and grounded it to the Bose amp metal enclosure. Unfortunately, I didn't take any pictures during the install. Here's a pic of the finished product.
Old Aug 7, 2004 | 10:44 AM
RamboRami's Avatar
G35driver.com Moderator
Re: 4080 box installed
cool man, looks great... now here's the kicker... (no pun intended) how does it sound!!?!?!??!?!?????
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Old Aug 7, 2004 | 02:55 PM
xswl0931's Avatar
Sounds pretty good, still need to spend some time tuning it. The only problem with mounting the amp on top of the Bose amp is that the amp controls are hidden away. Otherwise, I'm pretty happy with the setup.
Old Aug 8, 2004 | 10:45 AM
4080's Avatar
Make sure the x-over is set to low pass or lp. Start tuning the x-over at 80hz. If the bass sounds muddy lower the x-over in increments of 10hz untill you get smooth low bass that blends in with your front speakers.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
ZoominG35
Dec 6, 2015 03:11 PM
propho
Audio/Video/Electronics
Aug 27, 2015 04:56 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Frostbite91
Aug 2, 2015 04:59 PM
