Just had a Viper 5902 installed
Old Oct 31, 2009 | 12:39 PM
trunks333's Avatar
I just got the viper 5902 installed to protect my stereo system (12w7, AVN726e, Butler Tube amp, DLS iridium 6.3, Jl 500/1)
Everything can be set up on the remote (sensor sensitivity, engine run time, etc). The Remote tells you everything, if shock sensor is activated, or door is open, car running, etc. It reports to you every minute with a temp update when the car is running. Also had 2 modules installed, tilt sensor and talking voice module.
It was installed by an experienced installer for $225 and took about 6 hours. Had absolutely no problems. Everything works with the G35, engine start, trunk release, etc.
Old Oct 31, 2009 | 01:34 PM
blazeplacid's Avatar
looks pretty sweet
I remember how happy I was when we got mine done
even better that it was almost winter
Old Nov 3, 2009 | 03:47 AM
jin22gt's Avatar
I want the same alarm too.
Do you have the I-Key? If so, does it work well with the viper?
How much did the kit run you?
Do you know if it comes with window break sensor?
Did u test out the range of the remote?
Old Nov 3, 2009 | 03:49 AM
gizmo134's Avatar
curious if it will work with the i-key, i need an alarm but none that i know of work well.....
Old Nov 3, 2009 | 08:05 AM
trunks333's Avatar
I do not have a i-key, but it should work with the i-key with a bypass installed.
I purchased the alarm for $350 on ebay plus i used bing cashback.
The window break sensor is not included, only comes with a shock sensor. You can purchase the window break sensor for $15.
The range is pretty good. I parked at the end of a Walmart shopping lot and was able to start the car from the back of the store.
Old Nov 3, 2009 | 10:46 PM
gizmo134's Avatar
the only issue with the intellikey is that if you unlock the doors with the button on the door and open it, it will set the alarm off..
Old Mar 8, 2010 | 02:51 PM
Procharger G's Avatar
How much did the install cost you for it? I'm really thinking about purchasing one for my car now that I'm living in the city.
Old Mar 8, 2010 | 07:58 PM
trunks333's Avatar
$225 for installation with bypass included.
R350k5
Oct 1, 2015 08:41 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
