NAV Disclaimer Gone Forever & XBox on NAV Screen
Old Sep 9, 2004 | 02:07 AM
SI_G35Coupe's Avatar
Re: NAV Disclaimer Gone Forever & XBox on NAV Screen
um i discovered something the other day that might be important..... pressing the Agree button only works if the screen is UP on the G35.... if the screen is down a press on the joystick doesn't do anything, so i don't know if this mod will work without the screen being in the up position all the time
Old Sep 9, 2004 | 07:09 AM
Benzito's Avatar
You are correct SI G35 , The chip inside the module Generator is using can be programmed for multiple variety of tasks, We will be probably be working off the LCD power rather than the ignition 12v source(like in the muranos) for a triggering device, Therefore once the module "see's" the screen turn on it will run it's process and take you directly to the map. As far as difficulty goes it requires one soldering point on the back of the control board (as of right now). Once the install is complete on my vehicle I will post pics of all connection points.
Old Sep 9, 2004 | 07:32 AM
Benzito's Avatar
Djrobx I can see that lol, I will be following that post closely as I too am looking into adding another audio input along with Sat, I havent had much time to work on it but you seem to have alot of knowledge about this.Jaak from the murano forum has been working on adding another audio input to the pac unit , Theres alot of great info over there if anyone is interested. www.nissanmurano.org
Old Sep 30, 2004 | 11:27 AM
bump anything new on this mod?
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
Chauzilla
Sep 27, 2015 04:34 PM
G2B35AGN
Sep 25, 2015 10:49 PM
