Blown speaker or wiring issue?
Old Nov 19, 2009 | 06:54 PM
Kidd1077's Avatar
Two days ago, the left speakers in my sedan went out while i was listening to a cd. the front left door and rear left door. at first i thought i blew them, but when i turned to am radio, they both worked fine. What is the issue here? they make the noise of a blown speaker when on cd, but on radio they work.
Old Nov 22, 2009 | 12:09 PM
squabzter's Avatar
You need a new head unit. The circuit board is done
Old Nov 22, 2009 | 04:45 PM
Kidd1077's Avatar
can other people back this up, so im sure its true?
and so this means that if i get new speakers and amp them and change out the wiring, the left side still wont play?
Old Dec 22, 2009 | 03:10 AM
RADRaze2KX's Avatar
if you want to test your speakers, pull one out and do the 5v battery test... get a 5v AA or AAA battery, use 6" of speaker wire to connect: positive to positive on speaker, negative to negative on speaker... tap the positive... the speaker should move in and out. if it doesn't, your coil's hosed.
Old Jan 1, 2010 | 05:20 PM
jotsuka's Avatar
Yes... this has happened to me as well!!! so the circuit board is done? I need a new head unit?
Old Jan 1, 2010 | 06:13 PM
liche's Avatar
I don't think anyone here on the forum can tell you for sure what the issue other than just a "hunch." To know for sure, you'll have to diagnose the radio yourself or have someone do it for you.
I'm not saying those people aren't right, but before you go spend upwards of $1000 bucks for a new HU, amp, and what have you, i'd get the opinion of a professional before blindly following someone on a newsgroup thats never even seen your radio etc....
Old Jan 1, 2010 | 06:14 PM
liche's Avatar
Just a side note that polarity isn't important if you do this test.
whattf
Sep 1, 2015 07:42 PM
zcherub
Aug 30, 2015 05:04 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
Danielek
Aug 11, 2015 09:33 AM
