2004 G35x Install
Old Nov 25, 2009 | 10:25 PM
bruther's Avatar
2004 G35x Install
http://phoenixphorum.com/the-beginning-v-2-vt8357.html
Old Nov 26, 2009 | 12:12 PM
mattyjman's Avatar
didn't know you were on here too... good to see some cross posting!! I really like that install, very clean
Old Nov 26, 2009 | 12:21 PM
bruther's Avatar
Thanks man. I don't really post a lot......Working on the install today though. Trying to get the kicks up and running.
I'm waiting for you to finish up your ride so I can get some ideas.
Old Nov 26, 2009 | 06:34 PM
mattyjman's Avatar
well, i'm away for the holiday, so I hope to get started on the trunk this next week. I have everything drawn out for the final design, so i am excited to get things going there...
one thing i found is that if you have too much stuff it becomes hard to put everything all in...for the trunk i have one too many amps to fit with both 12's, so I am actually going to have to stack two of them (one will be essentially hidden)...
I need to order stuff for the fiberglass and vinyl, so that will be coming later than i hoped.
I really didn't expect all this to take so long, but as i begin different parts of the install, things keep changing and I have to adjust. I am going to put the tweets in the pillars now, instead of the kicks as I feel that with both the tweet and mid in the kick would be stuffing too much into the small kicks...
post up pics of your new revised install so i can watch... see what ideas I can get from you!!
Old Nov 27, 2009 | 06:53 PM
blazeplacid's Avatar
wow our car looks exactly the same
hahah
silver with MB wheels
This is the first time ive ever seen the wheels on another car and its on the same car as mine
Old Dec 5, 2009 | 09:07 PM
mattyjman's Avatar
bruther, in your kickpanels...how did you get the glass to stick to the panels?
Old Dec 5, 2009 | 09:57 PM
bruther's Avatar
Funny you should ask......I had a problem with it....I followed most people's advice and drilled holes in the factory kick panels but it still didn't work that well so I went ahead and used bondo to seal it to the panel around where the fiberglass meets the panel. Tomorrow I'm going to put resin on the back of the panel hoping the resin sinks into the holes I drilled. If that doesn't work.......I'm not sure.
Old Dec 12, 2009 | 10:40 AM
mattyjman's Avatar
the kicks are coming together nicely... i just started my layup lastnight... is your e-brake going to get in the way? seems like tight tolerances
TheKnite
Aug 14, 2015 07:59 PM
Jroc2017
Aug 12, 2015 11:21 AM
Srinidhi
Aug 7, 2015 03:38 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
