speaker size in 03 coupe
Old Dec 29, 2009 | 04:45 AM
monkix626's Avatar
before anybody says anything..i did use the search button=P
i kno that the front are 6.5 inches
the rears are 6x9
what i need to know is if the mid speakers are 6.5inches or 5.25? i've also read somewhere that the mounting dept for the mid speakers are pretty bad. thanks in advance.
Old Dec 30, 2009 | 11:22 AM
blazeplacid's Avatar
what do you mean "mid speaker" are you talking about the speaker in the door?
if so you have to make an adapter and you can chose if you want to make a hole large enough for a 6.5 or a 5.25
Old Dec 30, 2009 | 06:22 PM
mattyjman's Avatar
in the coupe, you have 6.5s in the front doors, tweets are small like .75" and not much depth, the rear quarter panel are 6.5s as well, but have a weird bracket and not actually built into the panels of the car, the rears are actually the subs, and yes 6x9's.
mounting depth is fine in the doors, just use a 3/4" mdf baffle... i have 10's in the doors. the rears, iirc should be somewhere around 2.5" mounting depth...
most people here sound like they do the fronts and the 6x9's and don't mess with the rear quarter panels... I advocate nothing in the rear and spending more on the fronts...
Old Dec 31, 2009 | 03:19 PM
Syndicate's Avatar
the mid speakers are 6.5's. when i changed out all of mine i just got some speaker spacers from http://cgi.ebay.com/Nissan-Infiniti-SPEAKER-SPACERS-350Z-G35-FX35-AND-MORE_W0QQitemZ300303661500QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45eb7e39bc and just used those for my front and mids and they worked perfect.
Old Dec 31, 2009 | 05:46 PM
liche's Avatar
If you're looking for speakers, I have a set of Infinity 60.7cs (Component Fronts) and Infinity 62.7is (Coaxial), both 6.5" speakers i'm selling in about two weeks.
Going to sell them all for $50.00 + shipping. These are 2 ohm speakers and work perfectly with the existing system in the car.
mjfenix
Aug 17, 2017 05:49 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
