clock lights
Old Jan 16, 2010 | 03:52 PM
canecorso1985's Avatar
clock lights
hey i have a 03 g35 sedan having trouble tryin to locate bulbs for the clock.ive tried grain of wheat bulb no luck.i live in burlington ontario canada does anyone have any info were to find replacement bulbs or how to convert to led light bulbs thx
Old Feb 3, 2010 | 09:15 PM
g7x5's Avatar
http://autolumination.com/74.htm
scroll down until you see,
get the type B
Introducing the SMT II Neowedge LED Bulbs
Now with dual SMT leds for 2x Brightenss
any of those with that base, when you take the clock out you should beable to swap them, you may actually have to take the led/bulb off the base and the swap them, i had to because the one they sent was just slight to big
Old Feb 4, 2010 | 06:46 PM
thx for the info
Old Feb 4, 2010 | 06:57 PM
BronxxBombers213's Avatar
yeah mine were a bit too big... im an idiot i didnt think to switch bases..., i dremmeled out the opening for the bulb a bit.... wish i hadnt done that... even though it works fine
Old Feb 9, 2010 | 02:10 PM
Angry
im havin more problems .ive got illumination problems now my running lights in the tail lights arent workn now and my whole center stack is not illuminating and my gauges are not dimmable they jus stay at the brighest setting.what tha **** IS GOIN ON????
Old Feb 9, 2010 | 02:52 PM
Mr. Samster's Avatar
try checking your fuses... there is a fuse box next to the battery. You have to take the battery cover off to get to it.
Old Feb 9, 2010 | 02:53 PM
g7x5's Avatar
check your fuses, there are should be some near the driver side kickpanel and behind the battery, not sure tho if the sedan is located as the same as the coupe, i have a coupe.
Old Feb 9, 2010 | 07:29 PM
yeah their located in tha same place.which ones should i be lookin at because i already checked them and they were fine but i wanna double check maybe i missed one?
Old Feb 9, 2010 | 07:45 PM
when my center console light went out and the rears i checked the fuse box located next to the battery. Not the one located next to the pedals.
Old Feb 9, 2010 | 08:10 PM
which fuse should i be lookin at?10 15 or 20 what is it labelled under
Old Feb 9, 2010 | 09:04 PM
15 i believe.... but if you use a flash light and shine it down you can see if the fuse is broken or not.
Old Feb 9, 2010 | 10:19 PM
thx to everyone for the info im gonna check tomm and will give some updates
Mry
Mar 3, 2023 01:03 AM
wonderizm
Sep 24, 2015 03:09 AM
flytim3
Sep 5, 2015 01:23 PM
underworld
Aug 6, 2015 01:36 PM
