lighting problems
Old Jan 21, 2010 | 06:58 PM
canecorso1985's Avatar
lighting problems
i need some help to find out why my center console lights arent working my front side marker lights are out also my rear lights are out but my brakes still light when depressed also my instrument cluster is stuck in the brightest dimmer mode and the dimmer switch does not work.what fuses to check checked bulbs their fine .if anyone one could help with this problem it would be graeatly appreciated ive been havn some bad luck with my 03 g35 4 door
Old Jan 21, 2010 | 07:41 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Fuses are in the driver's kick panel and under the hood. There is a little map inside the kick panel door, which will tell you which go to what. Ensure the car is in the off position and check each one associated with the offending lights.
Just as a sanity check, you are turning the light switch all the way to "definitely on", not auto, right? The instrument cluster stay on max bright whenever the lights aren't on. Are you headlights coming on?
If the fuse to turn on the other lights doesn't work, that'll keep the dimmer from dimming from daylight-view, as well as not turn on the sidemakers, tail lights and such.
Old Jan 22, 2010 | 09:02 PM
ive checked fusues none blown also checked bulbs are fine turn signals still workin also headlights and fog light are fine also my daytime running lights (canada) are workin.thx for the reply any other suggestions?
Old Jan 22, 2010 | 09:05 PM
yes the instrument cluster stays max dimmer all the time now
Old Jan 22, 2010 | 10:44 PM
All the fuses - both in the driver's kick panel and under the hood, right?
Old Jan 23, 2010 | 07:55 PM
yeah their all good i called infiniti they said they have alot of problem with the circuit boards on 03's i hope thats not it $300-1000
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
wonderizm
Sep 24, 2015 03:09 AM
Lsantana757
Jul 20, 2015 09:08 AM
attarday
Jul 15, 2015 04:03 PM
