PS2 power mod
Old Sep 1, 2004 | 06:51 PM
FrankieBallzzz's Avatar
PS2 power mod
anyone know how to remove the built in power converter so that I can connect my PS2 to my car's power source without the use of an inverter?
Thanks
Old Sep 1, 2004 | 08:27 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: PS2 power mod
Nope but it's pretty easy to spend $30 on an invertor.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old Sep 2, 2004 | 02:49 AM
Samstag's Avatar
Re: PS2 power mod
If you're talking about bypassing the PS2's internal power supply, it won't work. You need at least 2 different DC voltages, and you need them cleaner and more stable than you'll get from a car power system.
Surely you can spend a few more bucks on your $30,000+ car!
Old Sep 2, 2004 | 10:25 AM
Re: PS2 power mod
will i be able to watch movies while the car is in motion? i was reading in a few places that i would have to ground the hand brake or something. not too sure if that is true. i don't care about programming the nav while driving. i'm simply refering to watching dvds while the car is in motion.
Old Sep 2, 2004 | 11:33 AM
wizawuza's Avatar
Re: PS2 power mod
The navigation can't play dvd's. If, IF, you get the avelectronics (or whatever it's called??) system, or something similar, you can have the output of your ps2 displayed on the navigation screen.
If you do that, and play dvd's through the ps2, the status of the handbrake won't matter one bit.
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Old Sep 2, 2004 | 09:45 PM
Deep Sea Moderator
Re: PS2 power mod
I don't know about the other systems that have been going around lately but with the avelectronic unit there is a handbrake wire that when properly installed will only allow the screen to play movies when the handbrake is applied. Now if you accidently grounded that wire to the chasis it might (cough: will) allow you to display other video sources on your nav screen while the car is in motion.
Russ
Black 6MT Coupe
Jax, FL
Old Sep 3, 2004 | 01:52 AM
ikSardarG's Avatar
Re: PS2 power mod
Russ:
I still laugh whenever you say that... Funniest ish ever.
**** Official PAC Aux Input Dealer!!! ****
SWI-X units available also!
Navi-Conversion Kits at Discounted Pricing
*Authorized AV Electronic Dealer*
Old Sep 4, 2004 | 12:32 AM
crashTestDummy's Avatar
Re: PS2 power mod
Actually, the ps2 doesn't have any problem using the battery dc voltage. As far as removing the dc/ac inverter ... acna't help you there.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
zcherub
Sep 10, 2015 12:03 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
INVADER_6MT
Sep 3, 2015 01:47 AM
