Will 7" speakers fit the front of a g35 sedan?
Old Feb 1, 2010 | 04:09 PM
scareyourpassenger's Avatar
http://www.cdtaudio.com/pdf/ES-07.pdf
I was looking at these.
Old Feb 1, 2010 | 05:46 PM
liche's Avatar
Not without an adapter. I think with possibly a 0.5"-1" adapter plate, they would fit the stock hole. The key is getting the speaker high enough so the cone clears the OEM opening. The max. cone dimension from the drawing is about 5.87", as the speaker goes higher up, this dimensions reduces.
Old Feb 1, 2010 | 06:44 PM
mark1478's Avatar
i have 8s in my door. A lil cutting but worth it. a few peeps here run 10s i believe.
Old Feb 1, 2010 | 08:29 PM
mattyjman's Avatar
yep, they'll fit...cut away and make things happen
Old Feb 1, 2010 | 10:43 PM
I don't mind making an adapter but I don't want to cut the door panel. So which is it?
Old Feb 2, 2010 | 12:23 AM
mattyjman's Avatar
seriously...a 6.5 inch speaker fits. so if the speakers diameter is 1/4" bigger on each side for a total of another .5". You will be just fine. make a 3/4 mdf baffle, screw it into the door and the thickness of the mdf will give the basket enough room to taper before it goes through the whole
Old Feb 2, 2010 | 08:41 AM
Sounds good! Thanks everyone! I just want to make sure the car can go back to stock whenever we decide to part with it. May be a long time but I like to plan ahead.
Old Feb 2, 2010 | 11:45 AM
blazeplacid's Avatar
I running 6 7/8" ....yeah thats what I said to
so basically a 7", still plenty of room
1" thick on spacer
teamghost
Jul 28, 2015 04:52 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
