Check Engine after radio install
Old Feb 17, 2010 | 03:09 PM
ctk519's Avatar
Got the Service engine soon after radio install.
Did the manual ECU reset, but when you turn the car off and restart, SES again is lit.
What could be causing this?
I removed the negative lead to battery while doing a radio install and got the light upon completion. Everything seems to be working fine and the car is running the way it did before the install.
Haven't been able to get a scanner yet, but will be trying that soon to see what the code is.
Any ideas on why im getting the light would be helpful.
Again, the manual ecu reset works shortly, then the light comes back.
Old Feb 17, 2010 | 03:50 PM
tiguy99's Avatar
Won't know until u have it scanned and we can see what the code is
Old Feb 17, 2010 | 04:16 PM
blazeplacid's Avatar
by radio install do you mean just head unit swap or did you add amps/subs/etc?
is the car running weird?
do you have a Cold air intake?
possible you moved a vacuum line?
Old Feb 17, 2010 | 05:23 PM
ctk519's Avatar
Avic d-3, jl 500/1, eclipse sub.
Car is running fine
No cold air intake
Will double check vaccuum lines
Old Feb 17, 2010 | 05:32 PM
abcdo4dkIdjkm's Avatar
Happened to me after I did an amp install in the Z. Its some kind or rom error code. It happens if you connect, remove negative cable from battery terminal often. I cleared the code with a scanner and it never returned.
Ive heard other Z owners having the same problems after radio/amp installs.
Old Feb 17, 2010 | 07:25 PM
ctk519's Avatar
Here are the codes:
p0031
p0051
p0037
p0057
Checking into it now. If anyone knows what the codes are please let me know. Thanks
Edit: 02 sensor heater codes is what I'm coming up with. Did get my oil changed the other day. Would that have something to do with it?
Old Feb 17, 2010 | 07:45 PM
ctk519's Avatar
ISSUE Resolved:
Since I was trying to figure out what was wrong with my rear defroster, i was checking and replacing fuses.
I reinstalled the o2 sensor fuse in the wrong slot under the steering column panel.
I removed and inserted into correct o2 sensor slot, did a manual ecu reset and believe all is well.
Thanks for all your input.
Muski_G
Dec 1, 2023 11:11 AM
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
