Add amp and keep factory nav voice?
Old Sep 7, 2004 | 01:49 PM
FrankieBallzzz's Avatar
If I were to add an amp and change my speakers, but keep the stock headunit and stock nav, would I lose my nav voice? I think I would. If I'm correct, how would I go about installing speakers and an amp while keeping the Stock HU, and not lose my nav voice guidance?
Thanks,
Frank
Old Sep 7, 2004 | 02:08 PM
justICE's Avatar
Re: Add amp and keep factory nav voice?
You will not lose the navi voice if you add amps and speakers.
-JustICE
Rudy's Avatar
Sound Advice
You sould not lose the nav voice by changing the amp. The voice signal comes from the nav unit into the stock hu which goes into the amp, factory or aftermarket.
Do you hear me?
Old Sep 7, 2004 | 06:44 PM
GoSooners's Avatar
I've done what you plan on doing and I still have my voice prompts. The NAV lady is just louder now (because I tapped my LOC into my front signal).
But has anyonen figured out how to retain the Nav voice when changing out the HU? I know that you'd have to have a dedicated amp and speaker but which wire should be tapped in front?
Black on Black 5AT Coupe, Navi
Falken Koblenz 19x8.5 F 19x9.5 R
Falken FK-451 245/35 F 285/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
Old Sep 8, 2004 | 04:52 PM
djrobx's Avatar
Yes, it will work just fine. Just be sure to tap into the FRONT head unit output. The REAR head unit output does not have NAV voice. If you have a four channel LOC you can get an interersting effect by using the rear for the subwoofer. It's advantageous anyway since it lets you use fader to control the sub level. But what will happen is the music will cut off, but the sub will keep thumping while the nav speaks. It's kind of a neat effect.
-- Rob
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
TurTLe*
Sep 29, 2015 01:43 PM
