How many Line out put convetors for factory amp?
Old Mar 3, 2010 | 08:14 PM
Devinb30's Avatar
ok so im adding a aftermarket amp to my Stock bose head unit.
I read the sticky and i understand it. Except when adding the L.O.C it comes with 4 wires. (L+,L-) (R+,R-)... Does this tap into the rear speakers or front speakers?
Or do i need 2 Line out put convertors? (One for the front and one for the rear)?
Also do i tap it directly to the speakers? Or the speaker wires in the harness, that goes to the factory amp?
Old Mar 4, 2010 | 03:24 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
It depends.
You're adding an aftermarket amp, but you never said if it's going to drive a sub, two subs or four aftermarket speakers. That changes whether you're going to use one LOC or two.
Give a more complete description of what your desired endstate is and you'll get more answers.
Old Mar 4, 2010 | 06:43 PM
Devinb30's Avatar
Originally Posted by Wrathernaut
It depends.
Okay right now i have a Sub hooked up in my car with a LOC tapped into my harness that goes into my factory bose amp.
Im adding a Amplifier to push all my interior speakers because my factory amp blew.
Old Mar 5, 2010 | 01:45 AM
Okay, then you just need either an amp that can accept the balanced signal from the Bose headunit, or something to convert the balanced signal for your amp. See this thread for more info:
https://g35driver.com/forums/audio-v...m-regular.html
Since there's no amplified signal to convert, the LOC isn't doing anything - the output from the factory Bose headunit is a line-output already. Just use the four channels of unamplified signal wires that were going into the Bose amp.
jsimonk
Dec 22, 2023 03:49 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Thunderaan
Jul 22, 2015 07:40 PM
Jadenkid22
Jul 14, 2015 12:33 AM
