Non-Bose Front Speaker Upgrade
Old Mar 11, 2010 | 09:43 PM
Badboy8813's Avatar
would you guys recommend these speakers? and how hard would it be to install them? would it be a direct drop in?
http://www.crutchfield.com/p_500SPS6...=95&tab=review
Old Mar 11, 2010 | 10:12 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Crutchfield's install advisor:
2006 G35 with Factory Stereo
Selected location: Front Door
This item does not fit
Old Mar 11, 2010 | 10:13 PM
Use their "Outfit my car" tool to find something that'll go in easier.
Old Mar 11, 2010 | 10:36 PM
Badboy8813's Avatar
wow i can't believe i missed that... its getting late
Old Mar 11, 2010 | 10:43 PM
Badboy8813's Avatar
its says it fits
Old Mar 12, 2010 | 12:33 AM
My bad - I had Bose selected.
Old Mar 27, 2010 | 11:11 AM
abrahmh's Avatar
Its not too difficult to install the speakers. You will need a spacer / adapter. The "vehicle specific" adapter plate from crutchfield is not very good. You can either buy a set from a speaker enclosure site (about $20.00), or you can make your factory speaker into an adapter with a dremmel tool and a drill. My Non Bose factory speakers got fuzzy, and I replaced them (not for upgrade purposes). Initially I modified my factory speaker into an adapter spacer. Then I switched to MDF spacers, and it didn't sound any different. The nice thing about using the factory speaker as an adapter / spacer is that you can solder a wire between the new speaker leads, and the factory plug so when you are finished you just plug it in without cutting the harness in the car. I'm not sure how well the modified speaker spacer will work if you upgrade the system and increase the power to the speakers.
jsimonk
Dec 22, 2023 03:49 PM
mjfenix
Aug 17, 2017 05:49 AM
Blakelyg35
Aug 15, 2015 12:12 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
