Compass not accurate
Old Oct 27, 2002 | 02:49 AM
TallG35's Avatar
My G35 sedan has had the compass off by about 1/8 to the right (west) ever since day one. I tried the owner's manula calibration and the comapss would not respond ata ll like the owner's manual says. I took the car in and had them adjust it. My loaner G was off the same way. I got my car back and it seems perfect. I couldn't get a straight answer as to what they did.
Has anyone noticed their compass is off and corrected the calibration on their own?
TallG35
2003 G35 Sedan, Garnet Fire, VIN #398
Old Oct 27, 2002 | 12:12 PM
Gordgee's Avatar
Administrator
Re: Compass not accurate
The trick is to hold the button in as you turn on the ignition switch. If you have the car on when you try to reset the zones as the manual suggests, you'll clear the display after about 10 sec as you no doubt discovered.
Old Oct 27, 2002 | 10:12 PM
TheG35Guy's Avatar
Nothing beats a good old "floating ball" compass.
Dan Parmelee
2003 G35 Sedan
Stock
Old Oct 29, 2002 | 11:50 PM
wheels2's Avatar
My compass changes with the heater fan speed.
Old Nov 1, 2002 | 11:26 AM
Poindexter54's Avatar
To reset the compass, hold the buttons down like the manual says. The display will go to - - -.
Then drive around in circles in a parking lot going both directions. Figure eights work to.
Here's a video of Markham123 resetting his.
https://g35driver.com/media/g35Burnout.mpg
The compass will reset after about 3 minutes.
I had to do the same thing.
junon
Jan 14, 2023 09:37 PM
06gtfanatic
Aug 31, 2015 03:19 PM
Soumilg
Jul 23, 2015 09:26 AM
newbdriver01
Jul 16, 2015 11:35 AM
