07 G35x sedan sound system
Old Mar 28, 2010 | 10:25 AM
black07g35x's Avatar
hello to all G35 enthusiasts. Just purchased an 07 G35x sedan. Black with the chrome detail. I had an Acura, but this car is amazing. I am looking to install a sound system. My car does NOT have NAVI, but I have hooked up my Ipod using the A/V inputs in the arm rest. From what I understand this car has a subwoofer. Is that correct? Can it be replaced with an aftermarket one, and if so, will I have to install an aftermarket amp to power it? The mid speakers are just fine, I need a little more base and a cpl aftermarket tweets will not be bad either. Thanks for any help anyone here can lend. Cheers.
Old Mar 28, 2010 | 01:45 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
If you have the Bose system (It'll say Bose on it if you do) then it has a small, weak sub.
Yes, you can replace/install a sub.
Yes, you will have to install an aftermarket amp, since if you have the Bose system, it's amp is weak as hell, and if you don't have the Bose, you don't have one at all.
mjfenix
Aug 17, 2017 05:49 AM
Frostbite91
Aug 2, 2015 04:59 PM
BlackGee35
Jul 21, 2015 07:24 PM
mjfenix
Jul 14, 2015 10:37 PM
