Wiring Help Please!!!! Quick Questionss.
Old Mar 31, 2010 | 04:22 PM
ghuynh's Avatar
so i installed my double din dvd player and got no sound. audio place said i had to bypass the stock bose amp, but i wanna keep it. I got the metra 70-7551 harness and was told it will work. Only questions i have is what do i do with blue wire with white stripes and can i connect the amp ground wire to the other black wire? Please help me out. thanks in advance.
heres a link for a pic of the harness
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350325847822&rvr_id=&crlp=1_263602_263622&UA=%3F*F%3F&GUID=b5cecaa01270a0e201b1f4f1ffffba1b&itemid=350325847822&ff4=263602_263622
Old Mar 31, 2010 | 05:07 PM
whiteg35c2's Avatar
Sorry, mispost!
Last edited by whiteg35c2; Mar 31, 2010 at 05:09 PM. Reason: Oops misread question, or was it changed while I was writing the response
Old Apr 1, 2010 | 11:24 AM
ghuynh's Avatar
anyone??????
Old Apr 1, 2010 | 11:45 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Some headunits are extremely quiet when using the 70-7551 harness. You get louder sound when using the 70-7550 harness - The problem is, when using the 70-7550 harness, you get constant mild noise.
The best fix is to install a replacement amp, since you can't really bypass the Bose amp easily, since headunits output 4 channels of amplified signal, and your Bose system has at least 5 channels.
You'll need the swap to a 70-7550 harness to bypass the amp.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Jcruzg35
Sep 26, 2015 04:47 PM
