Installed a Basslink...
Old Sep 20, 2004 | 01:38 PM
roneski's Avatar
Devil's Advocate
I finally got around to installing a Basslink in my ride. The install was fairly easy. The only hard part was running the 8 gauge from the batt, but it wasn't too bad. I got it in with no modifications. It was a tight fit though, and I imagine that 4 gauge would be quite a bit more work. I had a wiring chart for the Bose amp, so splicing into the cable harnesses was pretty easy too. The Basslink fits well in the left rear corner of the trunk, again with no modifications. I also used a high/lo converter for the signal input to the amp. You can use the speaker level inputs with the Basslink, but I figured I may as well convert them.
I got roughly the sound quality that I was expecting from the unit. It's range is very good, though the quality of the bass was somewhat inaccurate. It tends to get muddy at moderate volumes, but not so much so that it is annoying. Take that last statement with a grain of salt though. My last system featured a 12w6 v2, so I may be a little spoiled. I am considering going to a traditional setup so that I can get a 10w6 v2, but it's going to cost me at least 3X as much as the $300 Basslink.
Pros-
Lightweight.
Good Value.
Easy install.
Adds a lot of bottom end that the coupe's stock system is missing.
Remote gain control is kind of a nice touch.
Acceptable spl.
Cons-
Bass is not accurate / muddy.
Overall I'd recommend it to anyone who is looking to add a simple subwoofer to round out the Gs stock system. Bass connoisseurs will not be satisfied however, but then again, they really wouldn't expect to be.
Ivory Coupe 5AT
Z tube, K&N drop in.
Fujitsubo Catback
Old Sep 20, 2004 | 02:18 PM
skaline's Avatar
Re: Installed a Basslink...
I have one in my Durango and I'm putting one in my G also. Works well enough for me. It's def. the best bang for the buck. Custom enclosure + Sub + Amp = too much $ for my budget.
My 350GT
Old Sep 20, 2004 | 05:34 PM
DJNOOCH's Avatar
G-Squad DJ =)
nice! got any pictures? i was afraid the basslink wont be LOUD enough or enough bass - anyone ever put TWO basslinks in a trunk? is it possible? how would it sound??
________________________________
'04 Coupe BS/G | Prem | Some Mods
Old Sep 21, 2004 | 12:43 AM
Sukairain's Avatar
I have the Basslink my my coupe as well. It fits perfectly in the left corner with some pushing. The unit is built for people who want to supplement music with more bass rather than people who want to be able to shake the street. It works very well for me. The remote volume control is an excellent freebie. I got mine installed for $280, well worth the money.
CPV35 G35C Maliblue
Old Sep 21, 2004 | 08:59 AM
cram's Avatar
I've had mine for aboout a year...Fills in the bass region very well.
I have it pushed more to the left than this pic shows, but facing up. It sounded clearer (less muddy) to me this way.
Craig Ramseur
G35C/5AT/BlkOb/Graphite/17"
PhxGold/Focal/AudioControlEQ/Basslink
Z-Xtreme Grounds/Z-Tube&PopCharger<P ID="edit"><FONT class="small"><EM>Edited by cram on 09/21/04 06:04 AM.</EM></FONT></P>
Old Sep 21, 2004 | 03:45 PM
skaline's Avatar
Is anyone using the mounting brackets or are you guys just pushing it into the corner? I'm afraid that it might move around during cornering. Any problems?
My 350GT
Old Sep 21, 2004 | 04:04 PM
Sukairain's Avatar
No mounting brackets, and no problems. I corner pretty hard, but the Basslink stays in place very well.
CPV35 G35C Maliblue
Old Sep 21, 2004 | 07:59 PM
roneski's Avatar
Devil's Advocate
Same her, I took it into an empty parking lot to throw it around a bit to see if it would come loose, but it didn't budge.
Ivory Coupe 5AT
Fujitsubo Catback
Old Sep 22, 2004 | 09:10 PM
6t8stang's Avatar
Mine is in the same location as Sukairain - pushed in it won't budge.
I installed the remote **** in the blank bezel below the truck/VDC/dimmer controls by your left knee...
2003 G35 Coupe 6MT
Brilliant Silver \ Willow Leather
Gilbertsville, PA
Old Sep 23, 2004 | 12:52 AM
skaline's Avatar
Any pics of that remote install. Sounds like a good spot. I havn't decided where to put mine yet.
My 350GT
Old Sep 23, 2004 | 06:43 PM
DJNOOCH's Avatar
G-Squad DJ =)
i wanna do the basslink i just wish i could hear it first - price wise its awesome but is it WORTH the price?
anyone ever try installing 2 basslinks?
Old Sep 24, 2004 | 12:40 AM
roneski's Avatar
Devil's Advocate
It sounds pretty good, it's not ground pounding bass, but it is a day and night difference between the stock system and the stock system with the Basslink. I suppose that 2 would naturally sound better than one.
I installed my remote in the storage compartment under the center armrest. I didn't mount it permanently yet, just used double sided tape. I wasn't sure if I'd like it there, but it works pretty well. It's not like I have to get at it all that often.
Ivory Coupe 5AT
Fujitsubo Catback
Old Oct 3, 2004 | 09:24 PM
6t8stang's Avatar
Sorry for the delay - here's the pic of my remote switch install...
2003 G35 Coupe 6MT
Gilbertsville, PA<P ID="edit"><FONT class="small"><EM>Edited by 6t8stang on 10/03/04 06:25 PM.</EM></FONT></P>
Old Oct 3, 2004 | 09:44 PM
skaline's Avatar
Nice! Very clean.
My 350GT
Old Oct 5, 2004 | 10:46 AM
praztek's Avatar
Anyone with a DIY for this on which wires to splice into?
Thanks
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
